Wiper door for 68
Old Mar 15, 2023 | 03:21 PM
Cobfree's Avatar
Cobfree
Default Wiper door for 68
I made a mistake and removed the wiper actuator, (big one for late 68) to paint it and improve the look. Well it looks great but I can get it adjusted to open the wiper cover when the wiper switch is one. How can I adjust it? Thanks
Old Mar 15, 2023 | 03:59 PM
kansas123's Avatar
kansas123
Rookie question: Is that shaft that comes out of the actuator threaded? On my '72 it is, and it's how you adjust how far the door opens when activated. Does anything at all happen when you turn on the wipers?
Old Mar 15, 2023 | 04:05 PM
Cobfree's Avatar
Cobfree
Yes it is treaded. When I turn them on the rod pushes all the way in and when off it is not retracting.
Old Mar 15, 2023 | 05:29 PM
MelWff's Avatar
MelWff
There are two vacuum lines connected to it.
Did you leave one off?
Old Mar 16, 2023 | 09:40 AM
Cobfree's Avatar
Cobfree
There are two, I guess I will disconnect from the push rod and try and adjust. I will also check the vacuum on both sides
Old Mar 22, 2023 | 07:51 PM
loup68's Avatar
loup68
Army
The wiper linkage thread is left hand and the actuator rod has a right hand thread. The connecting nut acts as a "turnbuckle" and adjusts the linkage. Next time do not turn the nut to remove the actuator and count how many turns of the actuator it takes to remove it. Lou.
Old Mar 23, 2023 | 08:38 AM
Cobfree's Avatar
Cobfree
Thanks for the info
Old Mar 23, 2023 | 07:06 PM
loup68's Avatar
loup68
Army
Your very welcome. I have had my 68 coupe for 50 1/2 years and anything that could break on the car has at least once! Check out my thread on C-3 general forum called "Long time chrome bumper owner speaks". Lou.
To Wiper door for 68
