AIM Drawings
Old Mar 22, 2023 | 02:54 PM
shidots69's Avatar
shidots69
Default AIM Drawings
So this is a weird find. The temperature sensor lead(Dark Green) obviously passes through the bulkhead connector . Funny thing that in the gauge side does not correspond with the engine compartment side( call it bulkhead connector #1). It appears that it lines up with the white-red-black lead which ends up at the coil. looking from the engine compartment side it lines up with the pink lead which goes to the ignition switch( call it bulkhead connector # 2) Hmmmm. Am I crazy or did I just stumble across an anomoly from 1969...
Old Mar 22, 2023 | 04:24 PM
shidots69's Avatar
shidots69
Old Mar 22, 2023 | 04:39 PM
Peterbuilt's Avatar
Peterbuilt
Default Are you reading that correctly?
The two halves fit together.
Put your palms face up the left thumb connects to the right thumb when you pray.
Old Mar 22, 2023 | 05:34 PM
shidots69's Avatar
shidots69
Agree to disagree. they are not lining up even if you pray. adjacent ones appear to be ok though...
To AIM Drawings
