Replacement Wilwood brake pads
Old Mar 26, 2023 | 04:55 PM
condor7's Avatar
condor7
Default Replacement Wilwood brake pads
I have Wilwood brakes on all four corners of my 1968 convertible. The fronts are the D8-6 and the rear are the D8-4. The brake pads on the car now are Wilwood, 150-10546K BP-10 compound pads medium temp and 150-10547K BP-20 compound pads medium temp. The pads work great except they throw a lot of brake dust. These have been on the car since 2015 but only have about 2K miles on them. I don't race the car it is just a street driver. I would like to change the pads to something from Power Stop or Hawk that has less or reduced brake dust. Would like to go ceramic pads as well. I can not seem to find the correct part numbers for these pads from either Power stop or Hawk. Can anyone help me out or point me in the correct direction. A different pad with good qualities? Thanks.
Old Mar 26, 2023 | 05:32 PM
KNSBrakes's Avatar
KNSBrakes
Supporting Vendor
That's a "D8" caliper based on the Wilwood p/n
https://www.knsbrakes.com/products/search/HB126
The Performance Ceramics should do the trick
-Ken
Old Mar 27, 2023 | 11:37 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
For a high quality low dust performance street brake pad take a look at the Carbotech 1521 brake pad 100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and contain NRS Technology Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
Carbotech brake pads can be ordered by calling me at 216-780-8825 Or order direct Here Ampd Autosport | One of the Largest Internet Retailer of Carbotech Per – Amp'd Autosport Use promo code z28 at check out for your forum discount.
The
Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Mar 27, 2023 | 11:40 AM
Carbotech Adam
Supporting Vendor
This would be the part numbers CT8 Brake Pad [REAR & FRONT] – Amp'd Autosport (ampdautosport.com)
Old Mar 27, 2023 | 03:02 PM
condor7's Avatar
condor7
Thank you for your response. I'm not sure which direction I will go just yet.
Old Mar 27, 2023 | 03:19 PM
condor7's Avatar
condor7
Originally Posted by Adam@Amp'dAutosport.com
Thank you for this information. These look like what I am wanting. Quick question, I read the description of compound but am not clear, are these ceramic? As I mentioned in my original post, My front caliper's are 6 piston and the rears are 4 piston. Also the link goes to the 1521 but it does not state if these are the "bobcat" series? Thanks again.
Old Mar 27, 2023 | 04:13 PM
SteveG75's Avatar
SteveG75
The Wilwood D8-6 and D8-4 calipers use the same pads as the stock Corvette calipers. You can get some good organic pads from NAPA and they will work just fine for street driving.
Old Mar 27, 2023 | 06:24 PM
Carbotech Adam
Supporting Vendor
1521 and bobcat are same pad. Please call me at 216-780-8825 to discuss. I have them your price for 1521 is $184.00 for front. Rear is same.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Mar 28, 2023 | 08:04 AM
condor7's Avatar
condor7
I was not aware of this. Certainly opens more options. Thanks.
Old Mar 28, 2023 | 08:52 AM
SteveG75's Avatar
SteveG75
Yup, the C2/C3 disk brake pads are coded D-8 in most parts catalogs. That is why Wilwood calls them the D8 caliper.
I have the same setup and have noticed that the Wilwood pads need some heat in them for maximum effectiveness. I have considered swapping to some good NAPA pads, just never got motivated to do so.
Alot of aftermarket pads give up some intial grip for improved grip when hot. If you are not racing your car or doing repeated panic stops on the street, organics can be better.
Who makes a good c3 brake pad? - CorvetteForum - Chevrolet Corvette Forum Discussion
Old Mar 28, 2023 | 10:25 AM
condor7's Avatar
condor7
A big thank you to everyone who helped me. I made a decision and bought the Power Stop Z23-008 for my Vette. I don't race or track the car, mainly I want a pad that stops good with little fade and virtually no brake dust. The Wilwood pads stop great but goodness they deposit a ton of brake dust, even in a short drive. Reason for the Power Stops. I also have a 2016 Vette. The OEM pads were terrible for brake dust. A few years ago I put on the Power Stops (The 2016) after reading about them in the C7 section. They are great. Almost no dust to speak of after a good drive and once I bedded then in a little the C7 will stop even better than the OEM pads. Again thanks to all especially SteveG75 for the information. Note: Got the pads at Rock Auto at a very good price.
To Replacement Wilwood brake pads
