Headlights - Not going up or turning on
Old Apr 3, 2023 | 10:37 PM
Max460's Avatar
Max460
3rd Gear
Default Headlights - Not going up or turning on
Hey Guys - Read through alot of posts on similar issues, but out of the blue, my C3 headlights do not go up, nor are they illuminating (when in down position or when I've maunally raided them). It could have been at least 12 months since id tunred them on, one used to be a bit slower than the other, but definitely worked. All other lights (parkers, dash lights, tail lights and "lights on" indicator on dash) work.
I replaced the switch immediately, no change.
I don't understand why bot the electrical system or vacuum system would fail at the same time unless it was the switch (I assume, but can't 100% recal, but when the switch is pulled on, it should illumiate the lights even if theyre stuck down or partialy open??)
I started down the vacuum system using the fault finding quide on the forum and diabrams. I almost has myself conviced the relays were sticky, so I fitted new ones, nothing.
I "isolated" the vacuum system to just the headlights (unplugged / re-routed any lines that were to do with windscreen washers as my vacuum testing was loosing some there.
At this stage, the only part of the system not consitantly holidng pressure is the "green" side of the LH headlight actualtor diaphram (so maybe front rod seal not 100%). It will manual lift when I pump in vacuum, but doesnt hold pressure up. Red side (down) all good. But even if I isolate that side, the RH still wont come up off the switch / with car vacuum. I can make both open and close by pumping up green or red tube on actuator independantly, but can't make it go up by pinching white signal tube tube when car running.
Pulling my hair out....and idea's why both "systems" may be at fault at same time?!?!
Old Apr 3, 2023 | 11:15 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
First off, what year do you have?
Secondly, can you manually push up both lights from underneath such that they lock and stay open by themselves? When they're fully locked open, have you tried cycling the dimmer switch?
When you pull the headlight switch to the first detent, do your parking lights illuminate?
Lastly, what city are you near? There are several Aussies here on the forum that may be able to assist in person.
Old Apr 3, 2023 | 11:28 PM
Max460's Avatar
Max460
3rd Gear
Hey Mate - In Cairns.
1973
I havn't "pushed" the lights open, but used a vauum pump on the green line to the actualtor, pumped them tpo the up position, then yes, they stay up and locked till I pump them back down on the red line.
Yes, when I pull on headlight switch to first detent and second, parker light up. All other lights work, tail lights, parkers, dash light, and "lights on indicator on dash"
No I havn't tried the dimmer switch when th lights are up (you mean the high / low beam dimmer / selector switch?
Cheers
Old Apr 3, 2023 | 11:44 PM
barkingrats
1973
Cheers
Sounds good that the parking, tail lights, and dash all light with the switch - that seems a good omen for the switch.
Yes, by dimmer switch I mean the high/low beam selector on the floor. I'm wondering if the switch is on low beam but the high beams work – it's just that you haven't tested that yet. Here's a recent post on the C2 forum about testing the H/L switch where the problem is no low beams (pre-'77 C3s share the same design as the C2s):
Originally Posted by 65GGvert
Most likely problem is the dimmer switch on the floor. The switch portion that feeds the low beams isn't working or the connector on the wire is loose, broken or corroded. You can buy the dimmer switch at most local auto parts stores very reasonably and it's held in by two screws and has a connector with three wires. The tan wire is the wire that feeds the low beams. The headlight switch cannot cause the problem because it feeds the same 12v to the blue wire on the dimmer whether in bright or dim position. You may want to hold on to that old headlight switch, you may find it works better than the replacement if it was original equipment switch.
If you pull the plug off the dimmer and short the blue wire to the tan wire and the dims come on, the dimmer switch is the problem. If not your problem is up front. (Two bad bulbs, a broken or disconnected tan wire on the drivers side connector will kill both dim beams) Another good way is to measure the tan wire with a voltmeter when the switch is pushed to dim with the headlights on.. If it's zero, the switch is bad.
Old Apr 4, 2023 | 12:02 AM
Max460's Avatar
Max460
3rd Gear
Thanks, I'll try dimmer switch!
However, am I correct in saying / assuming the electrical problem with the lights not coming on is unrelated to them not coming up?
Old Apr 4, 2023 | 12:51 AM
Peterbuilt's Avatar
Peterbuilt
Yes! You have two separate problems. To power up the lights electrically:
You changed the light switch, as the hoses are on correctly?
After the electric part is fixed Use this vacuum troubleshooting guide:
http://www.corvette-101.com/vacuum.htm
To Headlights - Not going up or turning on
