Coolant change
Old Apr 8, 2023 | 03:38 PM
Tim7282's Avatar
Tim7282
Default Coolant change
Does this video pretty much cover it all? Drain, flush, refill with 50% water?
Old Apr 8, 2023 | 03:54 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
uh, use distilled water not tap
Old Apr 8, 2023 | 04:49 PM
Tim7282's Avatar
Tim7282
Even for the flush?
Old Apr 8, 2023 | 05:08 PM
Tranz Zam's Avatar
Tranz Zam
Originally Posted by TimKeon
Even for the flush?
When I flush it I just run the garden hose through it.
Old Apr 8, 2023 | 05:13 PM
Tim7282's Avatar
Tim7282
Right, and then the final refill is 50% coolant and 50% distilled water, right?
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I do because not all fluid is drained thru petcock..
the video is adequate but is minimum method.
there is;
back flush
block drain
and multi vid method. refill with water after flush juice and run/drain.
regardless, the more distilled in verses tap water the better.
in the last steps.
so, drain, flush juice, tap water, drain, dist water, drain, coolant dist water.
Old Apr 8, 2023 | 05:21 PM
Tim7282's Avatar
Tim7282
Blocking off all of next Saturday ;(
Old Apr 8, 2023 | 05:44 PM
Tranz Zam's Avatar
Tranz Zam
Yes sir, unless you live in the frozen tundra.
Old Apr 8, 2023 | 07:38 PM
HeadsU.P.'s Avatar
HeadsU.P.
Get the front end up in the air. Ramps or even a couple 2 by 8s under the tires will help.
You want every last bubble in the entire cooling system to migrate forward and upward to the "open" radiator neck.
Old Apr 9, 2023 | 07:09 AM
Tim7282's Avatar
Tim7282
How about what coolant to use? Any recommendations for a base 350 in upstate NY?
Any validity to this stuff? https://www.evanscoolant.com/blog/mu...mance-coolant/
Old Apr 9, 2023 | 07:48 AM
Mr D.'s Avatar
Mr D.
Go into any FLAPS and buy premixed green 50/50 antifreeze, no need to over think this.
https://www.oreillyauto.com/detail/c...tifreeze&pos=1
Old Apr 9, 2023 | 12:38 PM
HeadsU.P.'s Avatar
HeadsU.P.
Tim,
There just has to be, a Wally World near you, I' m sure. Look for Prestone "pure" green concentrate. Get two jugs in the automotive section. Then onto to hardware for a big funnel. Then stroll over to groceries and get a jug or two of demineralized water. You can do all your mixing as you refill the Rad, just like a bartender. Simple.
Buying premix coolant is paying for half water. Why pay for water twice?
Old Apr 9, 2023 | 01:38 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
When I flushed mine I popped th cap and added the prestone flush and drove it for a few days, almost 100 miles. drained the block and the radiator...it was dark brown sludge. Repeated the process with just water and the prestone flush, drove it for a couple of days then drained it again...lighter brown sludge...Did it a third time and it came out almost clear....then I pulled the radiator and put a garden hose in the outlet with a rag for a seal and forced all the crud back out the inlet and it came out dark for a while and eventually went clear.....the car ran so much cooler after ward. I just filled it wilth the prestone 50 /50 mix because it was pretty cheap at the time...always used the green stuff
Old Apr 9, 2023 | 01:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
nice
Old Apr 9, 2023 | 02:16 PM
interpon's Avatar
interpon
I wasn’t aware we needed to flush coolant on a c3?
- heater core leaks….gallon
- radiator leaks gallon
- thermostat …gallon
- next….
I’m on the change it enough plan to not flush..
Old Apr 9, 2023 | 02:49 PM
Tranz Zam's Avatar
Tranz Zam
I usually pull the thermostat, disconnect the upper and lower hoses and run the garden hose through the engine until the water coming out is clear. Same with the radiator.
Dont over think it. I always buy the straight antifreeze and cut it 50/50 myself. You get two gallons from one for only a few dollars more. The pre mixed stuff isn't much cheaper, and you need to buy more of it.
Old Apr 10, 2023 | 07:33 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Problem with the garden hose is you still have a quart on each side in the block.......
This is not possible with some well worn blocks but I always pull the block plugs out of the sides of the block.......drain it right out.......then replace with 1/4" petcocks on each side of the block.....
Down here in Texas......the tap water is just crazy with calcium due to the aquafer.....you do not want even a little bit of this left in the block.......other areas have heavy rust in the water.......
I always buy concentrate and jugs of distilled water too as I don't mix 50/50 here....more like 75/25 water/antifreeze.....
Jebby
To Coolant change
Old Apr 10, 2023 | 07:52 AM
Rescue Rogers
My neck of the woods they add all sorts of weird chemicals to take out the arsenic and perchlorates as 2 examples. My Dad worked for the town and was talking to this shaby looking water debt guy carrying bottled water into the town hall. Dad asked him About the clothes and the guy said the chemicals he has to add at the pump stations did it. His new work boots were less than a month old and had holes eaten through them already
Old Apr 14, 2023 | 02:37 PM
Tim7282's Avatar
Tim7282
Have not done the coolant change yet. But I just ran the car for the first time since winter. Ran great. Drove it for about an hour. Got on it a little. Came home and found a coolant puddle on the driveway from the overflow tank drain. Is that an indication that it just needs the flush and change or is it something else like the thermostat? Temp only hit around 205 while driving.
Old Apr 14, 2023 | 03:30 PM
HeadsU.P.'s Avatar
HeadsU.P.
What is your Rad Cap pressure? I believe 15 -17 lbs should be the norm.
Boiling point of pure water is 212*. You were at 205*. But your Rad Cap relief still let go.
