Misfire and engine cuts out.
Old Apr 9, 2023 | 04:21 PM
sharrig's Avatar
sharrig
Navigator
Default Misfire and engine cuts out.
Hi,
Can you help me please? My 82 crossfire starts ok, and whilst pressing the accelerator drives ok. It is only when I press the accelerator hard, as I need more power to get away from a junction etc
does the car lose power misfires ( backfire through the exhaust ) and cuts out completely. After stopping the car, it does start straight away, and I can move off after gently pressing the throttle. I thought it may be a vacum leak, I have not found any leaks at the moment. Possible fuel of could it be an electrical problem?
Thank you for your response
Old Apr 9, 2023 | 04:45 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
so when the engine is under "load" the misfiring occurs?
some back story is needed.
did this problem just start?
was everything fine before?
any work done?
things like this info are needed to better help you
Old Apr 10, 2023 | 08:01 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
First thing you check on any Cross Fire Injected car is the fuel pressure......you need 13+ PSI to operate properly.
The symptom you describe could also be caused by bad injectors that will not flow enough fuel.......had this happen on my TBI Camaro twice over a 12 year period and had to replace injectors after the car sat for a long time (Michigan Winters).
Learn how to retrieve codes from your computer just to rule out fuel........fuel issues will not show up as a code.......if you have a code, address the issue.
Jebby
Old Apr 13, 2023 | 03:37 PM
sharrig's Avatar
sharrig
Navigator
I have had the car for a year and suffered no problems
Everything was fine before
Other than the rocker cover gaskets changed about six weeks ago, no other work done. After the work was completed, I took the car for a run several times with no issues.
Old Apr 13, 2023 | 04:52 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I think Jebby hit it on the head. Is it throwing any codes?
What is your fuel pressure?
Old Apr 13, 2023 | 04:57 PM
Fast81's Avatar
Fast81
Jebby
First culprit is fuel pressure aka fuel pump - now is the time to upgrade to an 85-87 tpi fuel pump that will feed your TBIs 13 psi even when its half dead. AND regasket the TBIs for the newfound pressure !!!!
To Misfire and engine cuts out.
