Air pump
Old Apr 10, 2023 | 08:33 PM
mikekapelus's Avatar
mikekapelus
Cruising
Default Air pump
I have replaced my catalytic converter with a magnaflow high flow converter and had to weld off the air tube. Recently I have noticed my air induction pump is making noise like the bearings are going. If I just remove the belt to the air pump does that do any harm? I’m in NJ and don’t need to test the exhaust for inspection.
Old Apr 11, 2023 | 04:41 AM
hunt4cleanair's Avatar
hunt4cleanair
Year?
All the pump does is inject air into the exhaust cycle for improved combustion. If the magnaflow converter operates as the original, then it may be looking for the 02 buzz. There may be carb adjustments but I'm sure others more familiar with your year and carb can suggest fixes.
Hope this helps!
PS: My suggestion is get the pump fixed given you are still using a converter...your engine is configured exhaust emission control.
Old Apr 11, 2023 | 06:06 AM
mikekapelus
Cruising
Originally Posted by hunt4cleanair
Year?
Hope this helps!
It’s a 1981, we had to close off the air tube to the catalytic converter because the new magnaflow cat doesn’t have a port for one. So if the air tube is welded shut does that mean the air pump is pretty much useless at this point?
Old Apr 11, 2023 | 07:33 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Yes, remove it and all of it's related components. There is 100% no drawback at all to removing it.....
Jebby
Old Apr 12, 2023 | 06:26 AM
hunt4cleanair
Jebby
To Air pump
