Camshaft recommendation
it’s a 1969, L46. The original engine is long gone. So I decided to replace it with a modern, ‘homage’ engine. A 400SBC, RPC aluminum heads, 11.0:1
The cam is compcam Xtreme Energy Hydraulic Roller 12-422-8
https://www.summitracing.com/parts/CCA-12-422-8
the DD2000 is:
It was designed to replicate the L-46 and then some. Which is does tremendously well. Vacuum is at 20 inches.
I have two problems with this cam. The off ramps are very aggressive leaving me with very noisy valve action. The valves are clacking away as the slam shut.
And secondly, low and mid are great, but it makes me drive it like a lazy man. It runs out of steam in my the 4000RPM range. (Manual) I think I need a bump to my bump stick and more
power in top end.
Is there something out there that would give me that and still enough vacuum to run my lights and wiper door ??
TBH, I was spoiled by my centrifugally supercharged 400 (previous ride). It made way north of 600. I guess I just need more.
MTIADC3
https://www.howardscams.com/hydrauli...cams-110255-10
If you want a smoother idle then you could use this one with a wider lobe separation.
https://www.howardscams.com/hydrauli...cams-110255-12
I have a Crower cam in my 400 with almost the same specs as above, but a 108 LSA and find the idle a little too rough as I get older....LOL
http://www.pbm-erson.com/Catalog/Ers...r_E/ERSE119847
230 dur is about the limit for a nice street cam. As long as you keep the lobe center at 110 or 112, it will idle OK and make decent vac. Stay away from the tight 106-108 LC if you want idle vac. Just a little more dur or less LC and it gets tempermental in a hurry. That's OK if that's what you want. The extra 16 degrees duration will make it pull hard to near 6k. Probably peak at 5600 vs the 4400 you have now.
My 230/240 cam made 15 inches of vac at an 850 idle in a 454. with a 110 lobe center.
Plenty for the vac system.
And it goes higher when you drive it anyway. That's just at idle.
Here is what mine sounded like on the Dyno FYI:
Jebby
power in top end.
MTIADC3
So your plan to increase the duration by 20 degrees is a good one. 214 + 20 yields 234. You're basically right on. Should rev/drive similar to the L46 cam, but in a 400.
The extreme cams do have very fast ramps, and yes that causes issues. I am not a fan. They are much fussier with parts selection, for not a lot of advantage. The Magnums have the old school slower ramps. So do the Howards. Better choice, and should be less noisy.
Now if you want a HR lifter motor to rev very well, to 6000 without pump-up, you are going to need some very good lifters. 6000 rpm is kind of their limit where a lot of them start having a hard time keeping up. I do not recall you mentioning what kind you have, but fast ramps require extremely good lifters to be able to avoid the noise. Quality cost money here. I would suggest doing some research here carefully to avoid more issues in the future. Don't forget the springs have to be carefully matched to both the cam, the rpm and the lifters. A 6000 rpm HR motor is not hard, but it won't work well with bargain parts, it needs some quality parts selection.
I would suggest some good quality springs designed for 6000+ rpm, and those will require some very good quality Hyd rollers. Then you will be very happy with a 230 ish Magnum cam or similar and it will buzz 6500 rpm easily if you want. HP will be waay up, like +100-150 or more. 460-480-500 depending on how good your heads and induction are.
A 108 LC with that duration will kill your vacuum, a 112 LC will keep enough to do what you want.
Good luck.
What lifters are you running now if you dont mind me asking? Im running enginetech retro roller lifters I bought on rock auto a couple years ago for like $130 for the set... They are noisier than my old voodoo flat tappet setup for sure.
But...where is your lash? 1/2 turn? Not enough lash makes them noisy......
I stopped using Comp and went to Howard's about ten years ago....just too many issues overall with several different things......Howard's applies the KISS principle....and I like that. I stopped using the X-Treme Comp grinds in a flat tappet when lobes started grinding away due to accelerated ramp profile......and the fact that the Magnum grinds made just as much power everywhere and sounded better......those are the only two cams I still use from Comp, the 280H and 292H Magnum........I have a Custom 292H Magnum flat tappet in my own 406 ground on a 108 LSA.......it pulls hard and revs free......
Also...do you have a premium .080 wall pushrod in there? A flexy pushrod can make noise on aggressive ramps......
Jebby
All my vacuum items worked great down to the 12 inch level at idle. I ran 383 and 396 ci sbc's in my vette since the early 90's both with around 11:1
I should have also prefaced. I’m 52.
With age, too lumpy is less desirable.
