Headers for a 75
Old May 6, 2023 | 06:42 AM
drywall guy's Avatar
drywall guy
Default Headers for a 75
I'll try to get to the issue. I have a 75 4sp and I installed a BP 383 stroker. The engine is fantastic,however I believe I chose the wrong headers. I used patriot block huggers that are awesome but the straight plugs on cylinders 3,4,5,6 are just too close. Has any one with this set up used headers that were better than this? I would be quite grateful for any input you guys may have... i'm not the greatest mechanic that ever lived, but t do understand what i'm trying to accomplish and that although I probably can make this work , would be open to a change.....Thanks again for any advice.
Oh btw factory a/c passenger side.
Old May 6, 2023 | 10:27 AM
randallsteel's Avatar
randallsteel
Too close as in the headers are touching the plugs? Or so close that you think the headers will melt the plug wires?
accel does make shorty spark plugs.
other options are denting the headers slightly to improve clearance.
Old May 6, 2023 | 02:06 PM
drywall guy
Default 75 headers
very close ....,i can get the bbot on but it touches....ol will try the shortys from
accel and denting them in a bit....'hoping to avoid complete switch .....thanks a lot man i appreciate the suggestion
Old May 8, 2023 | 07:50 AM
panther-19's Avatar
panther-19
Veteran: Marine Corps
I have ceramic coated Doug's headers on my 75 4-spd (converting to 5-spd) car. I have good plug clearance, but my clutch z-bar is very close on driver's side.
Old May 8, 2023 | 09:26 AM
taint's Avatar
taint
I have the same headers as Panther-19. No problems anywhere.
Old May 8, 2023 | 11:33 AM
drywall guy
Default headers for 75
Ok thanks ,,, either one if you guys happen to have a part number ? If not i can probably figure it out
Thanks for responding and trying to help me out
Old May 8, 2023 | 02:34 PM
MelWff's Avatar
MelWff
If you already don't have them try 90 degree boots and Accel shorty plugs. Cheaper and easier than new headers.
Old May 8, 2023 | 02:42 PM
taint's Avatar
taint
I couldn't find the receipt in any of my emails, so I'll check the invoice when I get home from work. If those plug wires MelWff suggested would work, you'd be about $700 better off.
Old May 8, 2023 | 03:43 PM
taint's Avatar
taint
Doug's Headers part number D350
WOW, they've gone up quite a bit.
Old May 8, 2023 | 06:01 PM
drywall guy
Default 75 headers
lol thanks for the part number ..... what hasn't gone up quite a bit.... sometimes i think if we all did the math we'd be pretty upset!!
To Headers for a 75
