1969 Corvette Battery Dying
Car runs fine, I do notice that the battery goes dead and I need to charge it on a regular basis.
I'm thinking probably a short somewhere, are there any known issues with this specific year?
Thanks,
Wade
https://www.corvetteforum.com/forums...with-pics.html
So, one of two things could be going on here, or both at the same time.
Your ALT is not producing one iota of juice back to the battery. So, your engine ignition, lighting, stereo, everything, is running off of the battery only, not running off the ALT output.
The battery is basically just for starting and the dome light when entering the car. After that event takes place, the ALT takes over for all the juice needed.
Or.
The ALT is producing around 14.6 V but a "parasitic draw (drain)" is removing all your juice when the vehicle is unoccupied.
Testing for a draw at the fuse panel will help a lot. But before you start pulling fuses with an OHM Meter, you need to take a block of wood and jamb it in between the front door jamb and the dome light switch.
It is so easy to move that it may be active. Turn it away from the passenger side. that is off. Wipers will work now and stops the drain.
I see that you live in Reno, Nevada. Heat is a batteries worst enemy. The hotter it is where they operate the shorter the life they will have. I used to build large Photovoltaic Solar system around the world. When I chose a battery to use in the United Arab Emirates the battery manufacturer suggested that the battery would need to be replaced after 18 and 24 months of use. This exact same battery would last 3 to 4 times as long in a cooler environment. I designed a patented Cooling system to keep the batteries cooler and used it. The customer was so surprised that they had not had to replace the $25k set of batteries after almost a decade of usage in the desert.
In my 1968 C3 I use the noise and thermal insulating material inside the battery box to protect the battery from the extreme heat. In your environment you might want to insulate the inside and outside of the battery box. The cooler the battery is kept the longer it will last.
I agree with checking the windshield washer over-ride. That is a very common cause of dead batteries in the early C3's.
There are so many types of "Battery Tenders" and some are good and some are not. I gave up on them and use my 10 amp battery charger to keep the battery charged up and the electrolyte mixed up properly. Low current charging is okay on Lead calcium batteries like those used in UPS applications. In our older Corvettes they were designed to use a Flooded Lead Acid battery and the standard FLA battery has liquid electrolyte that is made up of acid and Distilled Water. If you use a slow charger like a battery tender on a FLA battery it doesn't get the battery up to 15 volts which is where most FLA batteries start to gas and bubble. The gassing action is very helpful as it helps prevent the electrolyte from stratifying. Just be very careful as when a battery is gassing it is releasing Hydrogen and you want to do this type of charging where you have good ventilation. I suggest doing it outdoors unless you have good ventilation inside the garage.
As batteries start life they have a specific rate of self-discharge, this slowly increases after the battery has been in use. So a new battery will self discharge more slowly than an older battery does. Heat has an effect on this as well, the warmer it is the more self-discharging will happen inside the battery. When it is cold the battery looses capacity because the chemical actions that take place slow down, in the heat they speed up which leads to wearing out the battery more quickly.
Driving your Corvette is the very best way of helping your battery have a nice long life, Charging it with a 10 amp or larger charger is probably the second best way to maximize the life and capacity of the battery.
Here at my home I have 2 Corvettes and they both get battery service regularly. I remove the batteries, wipe off the top and then pop off the caps allowing me to see the electrolyte level inside the cells. If the cell shows the full marks exposed I then top the cell off with Distilled Water and replace the cap. Then I clean the terminals with a good battery brush and attach it to a battery charger that is powerful enough to get the battery up to 15 volts or 2.5 volts per cell. After the battery is recharged and has gassed I then wipe it down and re-install it in the car. I use battery grease and then cover the connection on the outside to keep oxygen from causing any issues inside the connection. Doing this has kept me from having any problems on the road that are battery related.
I used to use the little Blade style power switches or the ones that have the **** you turn to make the connection. Since I now have a EFI system and modern electronics I swapped out the old switches for a Marine Grade Circuit breaker. The breaker turns the power on quickly and securely. When the car is left sitting it is the most effective way to isolate the battery.
If you still have the original clock in your Corvette remove it and put it a modern version. The newer versions are more energy efficient. (So they tell us)
If your alternator has bad diodes in it then it can pull current. Using a Multi-meter to measure amperage you should be able to test for this. Another way is simply test for any Alternating Current coming out of the alternator. To do this simply put the meter on the A/C Voltage range and measure the output. If there is ANY A/C coming out of the alternator this too will kill a battery very quickly. This is another good item to test for!
You don't mention how old the battery is. That's where I'd start. Most of the time there's a sticker on the battery that can give you the mfg date. As mentioned, test the battery in the car - - - but if it's very old at all (4-5 years+) I'd just replace it. If I had to guess, I'd suggest that rather than a short or real parasitic loss you're dealing with a dead beat battery. Once you get that sorted, a good battery tender is your friend. Best, Paul
PS: pics!!!
