Intake manifold bolts
Old May 23, 2023 | 09:01 AM
Jim_A's Avatar
Jim_A
Default Intake manifold bolts
Morning
1968 C3 Intake manifold bolts. Were they installed before or after engine paint ? Should they be free of paint or painted engine color ?
and is correct finish blk oxide or bright ?
Thanks in advance
Jim
Old May 23, 2023 | 09:14 AM
PJO's Avatar
PJO
Veteran: Marine Corps
You will get a better answer if you add what engine combination your Corvette has.
Old May 23, 2023 | 09:50 AM
sunflower 1972's Avatar
sunflower 1972
Here's a photo of mine from when I just got it. It appears that the bolts are painted. I'm pretty sure GM was painting them in 1968 as well.
Old May 23, 2023 | 09:51 AM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I agree with PJO, however, generally speaking: if it's a cast iron intake, it was fully painted along with the bolts. Aluminum intakes were installed but the intake was roughly masked/shielded from getting painted but the very lower portion where they bolt to the heads received overspray and the adjacent bolts faces on the head sided show overspray as well.
Old May 23, 2023 | 10:02 AM
Jim_A's Avatar
Jim_A
Sorry,
Car is a 327/350....Survivor
Also, how were different fuel options acommodated (2x4 trips or whatever else was available. Each option would require a different manifold right?
BTW it is a cast iron manifold
Old May 23, 2023 | 10:57 AM
MelWff's Avatar
MelWff
Originally Posted by Jim_A
Sorry,
1968 had only two 327 engine options, 300 HP and 350 HP, both single 4bbl.
PJO's Avatar
PJO
Sorry,
Engine and manifold are painted as one. All 68 small block engines were single 4 barrel carburetor. Only 427 had 4 barrel carb and optional 3 2 barrel carbs or knows as tri-power.
Old May 23, 2023 | 10:59 AM
PJO's Avatar
PJO
Originally Posted by MelWff
1968 had only two 327 engine options, 300 HP and 350 HP, both single 4bbl, Quadrajet and Holley.
Only Rochester Quadrijet were installed on 68 small blocks. Some 427 had Holley"s
Old May 23, 2023 | 11:00 AM
MelWff's Avatar
MelWff
corrected
Old May 23, 2023 | 11:16 AM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
painted bolts
Old May 24, 2023 | 12:09 AM
barkingrats
Each engine option for a model year was completely assembled at the engine factory (Flint, Michigan, for all small blocks, Tonawanda, New York, for all big blocks). The factory stamped the option code for that specific engine configuration on the stamp pad (passenger side, front, below the head) along with the assembly date. They loaded racks with these engines and shipped them off to St. Louis. In St. Louis, the ordered engine was pulled from the appropriate rack of engines and stamped with a portion of the car's VIN on the same pad.
Here are two links to the process from John Hinckley, who unfortunately passed away a few years ago. He was a plant manager at the Corvette plant and is considered an expert in so many areas of Corvettes and Chevrolet in general.
http://www.camaros.org/flintV8.shtml
http://www.camaros.org/assemblyprocess.shtml#engine
To Intake manifold bolts
