GM Side Post Battery Terminal Bolts
Old May 30, 2023 | 11:05 AM
Buddythedog's Avatar
Buddythedog
Default GM Side Post Battery Terminal Bolts
I need to replace the original damaged side post battery terminal bolts for my 1972 Corvette. I am not sure which GM (ACDelco) part is appropriate for this model year: GM #1234949, GM #19115561, GM #8905400, or whatever part. Any advice would be appreciated. Thanks, BTD
Old May 31, 2023 | 08:34 AM
PJO's Avatar
PJO
Veteran: Marine Corps
This one 8905400 but the part number changed to this in 1972 8917444.
Old May 31, 2023 | 08:49 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Is there a difference between oem and the many aftermarkets that are available?
Old May 31, 2023 | 02:10 PM
Xlr8n1980's Avatar
Xlr8n1980
-Some are longer bolts to facilitate adding accessory terminals under the battery cable.
-In addition some of the aftermarket bolts in the OEM length aren't threaded as far down on the shaft which usually isn't a problem, but on some batteries you can't get them to seat tight to the cable which can lead to stripping of the battery threads if you attempt to strong-arm it.
Old Jun 2, 2023 | 08:07 AM
Buddythedog
Thank you for the information. Please excuse my delayed response: my laptop was down and out for the past two days. Just curious, but which part number would be in the aim for very early 1972's? 8917444? If so, I believe it cross references with gm #19115561 which I can purchase locally at any auto parts supplier. Please correct me if I am wrong. Thanks again.
To GM Side Post Battery Terminal Bolts
