Electric fuel pump recommendations.
Old May 30, 2023 | 12:52 PM
540 vette's Avatar
540 vette
Default Electric fuel pump recommendations.
What electric pump are you guys running. The engine is a 540. No mechanical boss on the block.
Old May 30, 2023 | 01:08 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
A1000 Aeromotive. One fed mine well into the 9's. Takes two of them to feed the turbo combo.
I don't run any voltage reducers etc....and have driven road trips of several thousand miles at a time with no issues. They DON'T like running out of fuel. That will eventually damage them.
JIM
Old May 30, 2023 | 02:31 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I recommend Magnafuel products......
Jebby
Old May 30, 2023 | 05:39 PM
69ttop502's Avatar
69ttop502
I second the Aeromotive A1000. Great pump! I am running the speed controller on mine.
Old May 30, 2023 | 05:52 PM
Amelio's Avatar
Amelio
I have Ben running a Holley Black pump for years with my SBC. Just swapped to a BB and left the pump in place. I believe back when I did the calculation the pump would provide everything my engine required per the power it made. Nothing fancy, real simple….run 1/2” feed with a 3/8” return and two filters.
I just got the BB running a few months ago so still getting it dialed in. Seems to be fine on the street but have zero data for track setup.
Old May 31, 2023 | 02:40 PM
540 vette's Avatar
540 vette
Any other recommendations.
Old May 31, 2023 | 02:47 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Weldon pumps are the finest there is.....but you pay a premium.....
Jebby
Old May 31, 2023 | 03:24 PM
Bikespace's Avatar
Bikespace
Any in-tank pump recommendations? Perhaps with a regulator mounted near where the stock pump lives?
Old May 31, 2023 | 07:33 PM
69ttop502's Avatar
69ttop502
I have my A1000 mounted in the tank.
Old Jun 4, 2023 | 02:11 PM
68/70Vette's Avatar
68/70Vette
JIM
The A1000 is a BIG pump. I've got one on my 70. According to Aeromotive tech support it needs AN 8 fuel lines going both ways from the tank to the regulator, up by the engine. Factory lines are AN 6. It's a little bit of squeeze to get two AN 8 lines between the body and the frame. I'm building a rolling frame so plumbing for AN 8 was "easy." Well, easier. Also, about running dry. I'm having a surge tank made help prevent the pump running dry.
My advice for an electric fuel pump: I think it's a good idea to get a speed controller for the A1000 or any pump. This runs the pump at reduced rpm at idle and off idle. Full pump rpm doesn't come in until rpm increases to where you need full pump delivery. Running the pump slow at low rpm makes less noise and less wear and tear on the motor. Imagine a long road trip lasting hours and running 2000 rpm at 70 mph. You don't need the pump running full rpm for hours. 3.73:1 rear end, Tramac 5 speed 498 cubic inches, 630 hp at 7000 rpm.
Old Jun 5, 2023 | 04:46 PM
ctmccloskey's Avatar
ctmccloskey
I am using a Holley In Tank Pump and regulator assembly that sends 60psi to my EFI system. On my 1968 it took very little time with an empty tank to install and wire the fuel pump. The Holley In Tank modules are available at efisystempro.com and here is the page that has the right pump for up to 1982 Corvettes:
.efisystempro.com/fuel-system/fuel-tank-modules/oe-style-fuel-tank-modules-chevy-corvette-78-82-12-313
It even comes with a section of the Hydra-Mat which works great all for $437.99
Old Jun 13, 2023 | 04:39 PM
540 vette's Avatar
540 vette
ttt
Old Jun 13, 2023 | 05:43 PM
Z0Tex's Avatar
Z0Tex
This is the way. Fuel pumps belong IN the fuel tank.
Old Jun 13, 2023 | 05:45 PM
540 vette's Avatar
540 vette
I can't put it in the tank. It's a fuel cell.
Old Jun 13, 2023 | 10:48 PM
Mdbirk's Avatar
Mdbirk
Holley 110 gph blue pump
https://www.holley.com/products/fuel...parts/12-802-1
To Electric fuel pump recommendations.
