79 power window switch replacements
Old May 31, 2023 | 08:35 PM
interpon's Avatar
interpon
Default 79 power window switch replacements
Hi,
passenger window switch was loosening or not tight to center. Now won’t go down but up.
any advice on best switch or replacing? Are they generic gm switch i should try nos?
thanks
Old May 31, 2023 | 08:40 PM
Peterbuilt's Avatar
Peterbuilt
Old May 31, 2023 | 09:10 PM
interpon's Avatar
interpon
Thank you! Never thought rebuildable.. i shall attempt
rip Willcox
i wonder of mine is loose if that is fixable
Old Jun 2, 2023 | 06:24 PM
interpon's Avatar
interpon
Remove passenger seat, front and middle screw side trim, remove 2 screws to liftslightly the console to access 9/32 scews..remove only forward screw loosen rear slightly raising to fit 1/4 socket to loosen, switch slides out. Pay attention to the small pin as they reverse from driver to passenger.
it appears the stakes let go and point’s basically fell out.
filed points, note reverse the plastic as it was worn through and protectfrom water..do not use tape where it rubbs as it squeaks compared to plastic.
3 hands stake with screwdriver hammer..seems to hold.
works great! Thanks for video saved me some $$
Old Jun 3, 2023 | 09:38 PM
Dodosmike's Avatar
Dodosmike
Looks great. Work?
Old Jun 3, 2023 | 09:42 PM
interpon's Avatar
interpon
Originally Posted by Dodosmike
Looks great. Work?
yup and thanks for your offer
Old Oct 12, 2024 | 06:43 AM
anewguy's Avatar
anewguy
Old Oct 12, 2024 | 06:45 AM
anewguy's Avatar
anewguy
To 79 power window switch replacements
