Origunal furl pump
Also I need a recommendation on buying a new water pump, again too many choices don't want to buy crap but something with a reasonable price.( cast iron or Aluminum)
that said simple enough once together to run pressure and flow test..
not a disaster to change out in car either..
Modern gasoline frequently has 10% ethanol mixed into it to help with emissions and the ethanol starts eating away at the older rubber right away. Newer parts are likely made with a newer version of rubber or material designed to handle the ethanol.
I switched from a Stewart's Water pump to a aluminum Edlebrock Water pump. The Edelbrock works great and looks awesome and cost less than the modified Stewart's pump. Having a 427 I am always looking to reduce the weight on the front of my engine and the Edelbrock's Chrome-like finish is very nice looking and pumps the fluid effectively.
JEGS carries the Stage 2 with the 5/8" pilot part # 935-22103 https://www.jegs.com/i/Stewart-Compo...22103/10002/-1
and with the 3/4" pilot part # 935-22203 https://www.jegs.com/i/Stewart-Compo...22203/10002/-1
Both are the short pump used on SB Corvettes and are made of heat-treated aluminum castings
You just need to know what size pilot you have, either 5/8" or 3/4" to be sure your pulleys will fit properly.
Whatever water pump you buy, you should also be prepared to move the hub on the pump shaft if necessary to get the exact pulley alignment you need for your application. I have rarely gotten a new water pump for a SB Chevy (of any manufacturer), that I was satisfied with and have found it is not difficult to move the hub if done carefully. Access to a hydraulic press will make this even less difficult.
Good luck... GUSTO
