Testing all cluster gauges 79
Old Jun 2, 2023 | 03:01 PM
Tylerstrickland's Avatar
Tylerstrickland
Default Testing all cluster gauges 79
New owner learning,
seems as though my gauges are all for show, or at least I don’t rust them.
I’ve been trying to locate all of my sensors so I can start the ground out method.
But what I think to be my temperature sensor has only one green wire.(first pic)
then the next sensor also has one wire(second pic)
driver side under alternator.
Just under distributor
Car is off
Old Jun 2, 2023 | 03:25 PM
Tylerstrickland
Update-
1) grounded wire in first pic maxed out temp gauge
2) then disconnected fully and bottomed out gauge
- conclusion gauge works and cleaned up connection as seen covered in oil.
Other gauges in progress
believe second pic is my oil pressure but converted to electric for some reason.
I’m going to make video on each successful check! (And attach link)
https://youtu.be/FTuTM1z1Mdc
Old Jun 2, 2023 | 04:18 PM
MattoonVette's Avatar
MattoonVette
Living the Vette life....
Sender in first picture is for your temperature.
Sender in second picture is for your oil pressure. It is factory.
No mechanical gauges were available, only electric gauges and senders for your year. Both the temp and oil pressure only used a single wire.
Old Jun 3, 2023 | 10:17 PM
Tylerstrickland
Default Small leak in exhaust manifold
thank you for the knowledge. There’s a slight leak I have here which from exhaust manifold. It looks like something doesn’t line up correctly.
hard to tell from pic but on the corner there looks like a flap of gasket and a hole in it to a hole in block for a bolt
Old Jun 8, 2023 | 10:52 PM
Tylerstrickland
Default Update
Oil pressure sensor and gauge work, temp gauge and gas gauge work.
I have to add some gas and look for any change in it.
To Testing all cluster gauges 79
