1975 Fan Shroud Question
I have the assembly manual but I can't tell for sure. Is the shroud supposed to tuck into the gap between the side tank and fins or does it sit on top of the ridge on the side tank?
I'm chasing an issue with the car getting hot at idle with the AC on (230+ after 5 minutes of idling on an 85 degree day, verified with a laser thermometer). It hasn't boiled over but 85 is not where we top out here in Texas. Once I'm moving, the temp hovers between 200 and 205 whether on surface streets or the highway. I'm pretty convinced that if I got stuck in traffic on a 95+ degree day, I'd be in trouble. Radiator support, radiator (standard brass) and shroud have all been replaced by PO within the last 5 years or so. Radiator to support seals are there as is the hood seal. The bottom seal on the shroud is there but the top seal is missing and the side seals aren't making proper contact with the radiator. One side of the shroud is tucked into the gap between the fins and and tank but the other side is not and there's half inch gap between it and the radiator. I'm trying to get the radiator bits sealed up correctly to reassess the situation before traveling down the path of electric fans with the requisite electrical upgrades that go along with that. I have a stage 1 Stewart high flow water pump and a 180 degree t-stat that I put in this year. The fan is a 6 blade fan installed by PO with an unknown clutch but the clutch "seems" to be working correctly as it only spins a few rotations when I kill the engine after it's hot. The fan IS a little deep into the shroud I think, a bit more than half way due to me having to shim it out to keep the clutch from bottoming out on the water pump shaft. All of the air has been purged from the system and the timing has been meticulously set following Lar's papers after verifying TDC with a piston stop tool. The carb was rebuilt by the man himself late last year so I'm 100% confident it is setup correctly.
I'm also missing the rubber flaps that cover the control arms. Are those at all relevant to cooling the engine compartment?
Appreciate any insight on what else I should check after the shroud is sealed up if I've missed anything obvious. I've just rewired the whole car with Lectric Limited parts and I hate the thought of having to dig into my brand new harnesses to run upgraded wiring to support a larger alternator and electric fans if I don't really need to.
Thanks!
how about some pics??
no reason correct OEM setup should not work.
look close at fins inside radiator for openness ..an aluminum radiator i think would help everything..
they will gain temp at idle and ac…that condenser preheats the air pretty good so your ac must be working good!
Appreciate the comments. Thank you! I'll take some pics and post up.
Data point --> Water boiling point is 212F, at 15 psi (radiator cap) that boiling point is increased to 249.8F. A 50/50 mix of water and antifreeze will add 11F buffer to those number so in reality the car pukes out the overflow when the water temp is 260F or higher.
You stated the car doesn't puke out the overflow so we're looking at reducing the operating temperature vice fixing something that is broke causing an over temp condition. I would start with verifying the engine timing is correct first and then move on to what is not OEM correct. Couple thoughts right out of the box based on your statements is the fan being too far into the shroud and a stage 1 Stewart high flow water pump. If water is being pushed through the radiator too fast it doesn't have time to cool or in simple terms it's not letting the radiator do its job. There should be about a 20 degree difference in the inlet and outlet temperature if the radiator is doing its job.
Because you don't have a boiling out the overflow problem I would also verify or the best you can verify that the temperature of the coolant exiting the engine block matches the temperature gauge or is close. An IR gun will prove to be your best tool for this. Not unheard of for a mismatch between the sender and gauge causing a 10 to 20 degree difference.
Keep us updated on this as we all can learn from these over temp issues.
Below is a link from 2008 when I was chasing a temp problem on my 65 Vette.
https://www.corvetteforum.com/forums...ed-for-me.html
https://www.corvetteforum.com/forums...replace-2.html
An electric setup can cost as little as $300 with the high amp alternator the OP will need.
Op I would try sealing up the factory shroud better first abd make sure your clutch isnt bad.
And ignore the tip to remove your lower spoiler to help. That will do the very opposite of helping things.
Ill tell you what... Going electric with my fans was one of the best day and night differences I seen with my 74, which I did AFTER replacing my radiator, hoses clutch, seals and multiple thermostats...
And now it's way easier to work on things in my engine compartment such as replacing my A arms/ bushings and adding the a arm brace.
And it's a great way to gain 7-14 dyno proven hp vs a functioning clutch fan
I did some additional data collection this morning after reading your post. Keeping in mind that ambient was only around 70, I drove around for 20 minutes and then let it idle for 20 minutes with the AC on and the hood closed. I did put the top seal on the fan shroud because it was easy but one side is still not sealed up properly. Inlet temp as measured on the radiator inlet itself with an infrared thermometer was at 237, outlet temp was at 204.
As far as OEM type parts. This car is definitely a hodgepodge. Engine is not original, the pulleys they used seem to be a mismatch of bits. The part number on the crank pulley for example comes back to a big block and I don't know for certain what the water pump pulley is from. I had a heck of a time finding a water pump that would let me get the pulleys even close to lining up and when I did, the shaft is sticking so far out of the fan flange, it bottoms out in the clutch before the fan can fully seat, thus the necessity to shim it out a bit. The radiator is OEM style and not aluminum and the shroud is re-pop from Corvette America or Zip. It's filled with premixed Prestone antifreeze which is around 6 months old with maybe 300 miles on it. I recently installed a new temp sender from Lectric Limited specifically calibrated for a 75 Corvette. With the previous sender, the gauge was never getting above 150 degrees.
It's hard to get pics that show any relevant information but here's a few just to give us all something to look at.
Fan depth into shroud
Radiator and Shroud installation
Gauge after idling 20 minutes with the AC on.
Factory fans are very carefully designed for maximum efficiency (and minimum noise, which is why the blade positions are staggered), and are designed to provide maximum efficiency when the tips of the blades are half-in/half-out of the rear edge of the shroud, with approximately 1/2” clearance from the blade tips to the shroud. The radiator/shroud/fan combination on each Corvette is the result of a lot of tedious hot-weather development work by the engineers who designed it, and the original system is tough to improve on, assuming that all the components of the cooling system are functioning properly and haven’t been butchered, altered, removed, substituted, or backyard- engineered to “improve” them. These cars didn’t overheat when they were new, and they shouldn’t now, if the “system” is still composed of the correctly configured components.
