Borgeson leaks bad
Old Jun 6, 2023 | 07:28 PM
Steve Stroman's Avatar
Steve Stroman
Default Borgeson leaks bad
I was advised to use the o-ring to flare adapters. I bought them, but can't get the grommet things out. Any tips?
TiA
Old Jun 6, 2023 | 09:34 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I heard several people say the little insert adapters tend to leak.
You could just go to a hydraulic hose shop and they could make a custom hose with the correct fitting, for very little money. Or add the correct end on the hose that you have, that requires an adapter.
Old Jun 6, 2023 | 09:46 PM
Steve Stroman
I have the hoses and adapters, need to remove the inserts.
Old Jun 7, 2023 | 06:17 AM
CraigH's Avatar
CraigH
I will be interested in hearing from someone who has removed them as well as I will at some stage be replacing the Borgeson hoses with new ones with an o-ring an fittings.
One thought I had was to use a “screw remover” in it then pull it up.
Old Jun 7, 2023 | 07:18 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
My experience with the Borgeson as far as lines go at the box was that both ports are drilled too deep.....you buy the little inserts that go in there and the flare nut at the line bottoms out.........I solved this with those brass flare washers/shims.....worked like a charm.
The inserts can be removed with a screw on the end of a slide hammer/dent puller.....
Jebby
Old Jun 7, 2023 | 09:14 AM
SH-60B's Avatar
SH-60B
Jebby
Jebby where can I get the brass flare washers?
Old Jun 7, 2023 | 09:32 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
From the Bezos train.....
Amazon.com : parker flare gasket Amazon.com : parker flare gasket
Jebby
Old Jun 7, 2023 | 01:33 PM
SH-60B's Avatar
SH-60B
Jebby
Thanks!
Old Jun 7, 2023 | 01:49 PM
Steve Stroman
The guy from Borgeson said an email out, what size would I need?
Old Jun 7, 2023 | 01:59 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Of flare gaskets? If so I am not 100% sure....I bought several different sizes due to time constraints and knew I would use them on other ****......
Grainger has them too:
For 3/16 in Tube OD, Flared, Flare Gasket - 5WRW0|2GF-3 - Grainger
These lifesavers are also good for stainless lines on anything.......especially brake lines.....
Jebby
Old Jun 7, 2023 | 02:02 PM
Steve Stroman
I meant EZ out, not email.
Wondering what size so I don't mess up the port.
Old Jun 7, 2023 | 02:20 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
They have those 5 pack deals at the Auto Parts......it should have what you need...they aren't terribly expensive.....Vermont American is the pack I have.....
Vermont American 21822 5-Piece Extractor Set 45325218228 | eBay
Jebby
Old Jun 7, 2023 | 08:46 PM
Steve Stroman
A #4 screw extractor did the job easily. Thanks to Jebby for the help.
To Borgeson leaks bad
