Another interior door handle question?
Old Jun 12, 2023 | 05:33 AM
Z51JEFF's Avatar
Z51JEFF
Default Another interior door handle question?
Did a search and pulled up everything but what I was looking for. What's the easiest way the get the door handle back on?
Old Jun 12, 2023 | 07:17 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
2 screwdrivers, plain sloted type. Med sized one, slide it into the slot that the handle slides into. Lift gently being careful not to break the aluminium channel. Lift just enough to get a large screwdriver behind the mechanism. Now lift mechanism more into the open position while removing the first screwdriver. While holding mechanism out with large screwdriver, slide handle into the channel and then install the Phillips head screw.
I ran a how to thread awhile back on replacing door hinge bushings. I believe I have photos in that thread on how to do just this.
Old Jun 12, 2023 | 07:22 AM
4-vettes's Avatar
4-vettes
Perhaps this will help.
Old Jun 12, 2023 | 09:27 AM
Eliredandblack's Avatar
Eliredandblack
I use a flat bake screwdriver (or other flat blade tool) that will ENGAGE Both Groves on the pot metal receiver, then I use a piece of plastic to wedge the pot metal receiver in the open position, like the photo above. If you only engage one of the groves, there is a chance you will brake it off, don’t ask me how I know!
To Another interior door handle question?
