Mornng Fellas,
Having trouble with recurrent flooding in my 68 327/350 Rochester Quadra-Jet 7028212, Seems after car sits for 2-3 day's and you try to start it, it has decided no way, The conditions I found were an extreme amounat of gasoline in the Oil.....??????? (appx 1/2 gallon). It refused to start with PCV valve connected. Pinch off the hose or pull the PCV valve and I got it to start. Changed the oil and filter and new needle , seat and float. Yesterday the same damn thing is happening. Any comments or idea's welcome. Please help me solve this !!!
If I remember correctly reading Lars papers....the 68 Q-Jet is the one that gave the Q-Jet a bad rap......it is the only model year that the well plugs actually leaked on........you may have this happening because there is literally nothing else that could cause a buttload of fuel to dump down the intake in a not running state.
I suggest you take the unit off and send it to him........
The half gallon of gas in your oil must be over a bunch of running cycles as the Q-Jet only holds about 3oz. of fuel I believe.....
The reason it fires with the pcv pulled is you are introducing a buttload of air to go with your buttload of fuel......
Lars may chime in here....
Thanks for your comment Jebby. That sounds like exactly what is happening. I would love to send it to someone. (sorry for my stupidity ) Who is Lars? where do I send it
I would also check the fuel pump for an internal leak into the crankcase. With all of that fuel in the oil, I would carefully change the oil and filter. Jerry
Out of curiosity, how do you know 1/2 gallon of fuel was in the oil? Since gas and oil mix completely, was your oil level the equivalent of 2 quarts over-filled?
I don't see how leaking well-plugs are going to add that much fuel to the crankcase. Would be extremely rich, soaking wet spark plugs, etc., but how would it get to the crankcase without other hugely obvious symptoms? That quantity of fuel sounds like fuel pump.
The fuel pump could be leaking into the crankcase but only when it is running.....and would cause no start, flooding style conditions.....
