help with wire identification, 1974 L48
Old Jun 16, 2023 | 05:49 PM
rgouette's Avatar
rgouette
Default help with wire identification, 1974 L48
i’m not up to speed on symbology and nomenclature for schematics .In the picture, can somebody tell me how to interpret the circled wire?
Thanks fellas,
Rich
Old Jun 16, 2023 | 06:52 PM
Peterbuilt's Avatar
Peterbuilt
That PPL wire connects to the 'S' terminal on the starter solenoid.
It turns on the starter when the key is in 'START'.
Old Jun 16, 2023 | 07:03 PM
rgouette's Avatar
rgouette
ok, I didn;t explain well, sometimes I suck a little at online communication of my thoughts..
I know about the purple wire, & figured this was it.
What I'm asking for is how does one interpret: 6A-12-PPL(GBS) ?
I've got the manual with diagrams, but I'm not quite sure what the syntax is...
Appreciate the help,
R
Old Jun 16, 2023 | 07:05 PM
Greg's Avatar
Greg
Just another Corvette guy
Old Jun 16, 2023 | 07:09 PM
rgouette's Avatar
rgouette
Originally Posted by Greg
weird, the only thing the forum is displaying from your post is "..."
I do see the text in email..
Anywhoo, I'm working on the starting circuit.
R
Old Jun 16, 2023 | 07:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
6a should be wire no in drawing/s and 12 is size/gauge
Old Jun 16, 2023 | 07:29 PM
Greg's Avatar
Greg
Yes, Mr. D's explanation below is correct.
Old Jun 16, 2023 | 07:30 PM
Mr D.'s Avatar
Mr D.
What Greg said
Old Jun 16, 2023 | 07:49 PM
rgouette's Avatar
rgouette
thx all
~R
Old Jun 16, 2023 | 08:35 PM
bmotojoe's Avatar
bmotojoe
6 is the common circuit number, if you follow circuit 6 out it "May" be associated with the Starter Interlock override relay labeled 6C
At the bulkhead connector it is labeled 6B
You can see where this is going...
When you draw a line between point A and all points in between it is all part of circuit 6...
Old Jun 16, 2023 | 09:24 PM
Peterbuilt's Avatar
Peterbuilt
The circuit numbers are listed in the 1974 Service manual on page 12-78.
To help with wire identification, 1974 L48
