Camaro Rims
Old Jun 21, 2023 | 06:19 PM
rdemart130's Avatar
rdemart130
Navigator
Default Camaro Rims
can anyone tell me if the 5 spoke rims off a 70-71 Z/28 will fit my 1972 LT-1 corvette? If not are there spacers or adapters that will make them fit? What is the optimum tire size?
Old Jun 21, 2023 | 06:31 PM
68-427Rich's Avatar
68-427Rich
Those wheels have 4¼" back spacing. The Corvette rally wheels have 4" back spacing.
There may be an interference problem at the steering arm or tie rod end.
The Camaro wheels have "nubs" welded on the back to center them on the hub or axle.
This is called hub centric.
If you use a spacer, you will not have the wheel located by the nubs and will be depending on the lug nuts for that.
Old Jun 21, 2023 | 11:07 PM
gbvette62's Avatar
gbvette62
The Z/28 wheels are 15x7, narrower then the 72 Corvettes 15x8 rally wheel. I can't imagine any reason to put a narrower then stock wheel on a Corvette, or any car. When using rims with a backspacing of more than 4" often causes interference with the trailing arms and parking brake cable bracket.
Old Jun 23, 2023 | 05:25 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Don't forget that the 'Vette calipers are pretty big, and might interfere with the backside of the Camaro wheel's center section....
To Camaro Rims
