Project Vettefinders 79 needs some help
I was lucky with my 78 and didn't have this problem.
Air chisel?
Bob
rotary file end - or stones - to grind the head off the bolt.
A dremel tool will do it - but the going is slow.
A 3" air powered cut-off tool might fit in the kick panel area, but not the #3s.
If you remove the bonded fiberglass panel just front of the rear wheels, you
might be able to get into the nut/bracket area enough to chisel off the bracket.
It sounds like you need to take 'em off to repair them - anyway.
Here is my 75 with the FG panel removed - and the rocker channel, too!
[Modified by NHvette, 5:53 PM 1/20/2003]
You'll need a sharp (new) blade, some cutting fluid, and lots of patience. I went this route because I couldn't get the die grinder or cut-off wheel into the access hole.
The blade holder really made the job go easily, and the second one only took half the time of the first one. I had trouble with 6 of the 8 bolts. The heads broke off two, I cut the heads off of two more, and used a reciprocating saw on the rear two.
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6754
