windshield wipers
Old Jun 27, 2023 | 09:33 AM
reed woodman's Avatar
reed woodman
5th Gear
Default windshield wipers
i have a 1975 corvette 4 speed. my windshield wipers will not work when the door is closed but will work when the door is open. is there something wrong with my ignition switch?
Old Jun 27, 2023 | 12:57 PM
MelWff's Avatar
MelWff
Just to be clear. With the engine running, all car doors closed, you turn on the wipers and nothing happens. You then open the drivers door and they work?
Old Jun 27, 2023 | 01:31 PM
reed woodman
5th Gear
yes. my radio also does not save the channels i program. that may be a radio problem
Old Jun 27, 2023 | 01:34 PM
reed woodman
5th Gear
my engine is not running at the time but my key is on. steve
Old Jun 27, 2023 | 01:45 PM
MelWff's Avatar
MelWff
That sounds like whoever installed the non-factory radio didn't correctly wire the constant power connection.
MelWff's Avatar
MelWff
what happens if the engine is running, same problem?
Old Jun 27, 2023 | 02:30 PM
reed woodman
5th Gear
yes
Old Jun 27, 2023 | 02:59 PM
MelWff's Avatar
MelWff
Is this car a new purchase or you have had it for awhile and this is a recent problem?
Old Jun 27, 2023 | 03:25 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Sounds like a ground issue. the door switch connects aground when open so you must have a bad ground at the wiper and its seeking aground and finds the door switch.....thats going to be fun tracing
Old Jun 28, 2023 | 07:02 PM
jeffstuarts's Avatar
jeffstuarts
What is probably happening is that the wiper is grounding through the alarm system. Many years ago I had the same issue with my '69 that is equipped with the factory alarm. The wiper ground at the starter was broken. The wiper then used the path of least resistance which was through the alarm. On the '69 that is piggy backed to the wiper ground. When the door is open the alarm is grounded.
Jeff
Old Jun 30, 2023 | 07:38 AM
reed woodman
5th Gear
It was a ground wire off. Thanks for the help
Old Jun 30, 2023 | 05:16 PM
JBrooke825's Avatar
JBrooke825
2018 C3 of Year Finalist
I know I have more than one,just in case.
To windshield wipers
