82 what rear gears
Old Jun 28, 2023 | 02:46 PM
trans am kev's Avatar
trans am kev
Default 82 what rear gears
hello all i have an 82 vette with a sbc blueprint 427 it as a t56 magnum close ratio . what would be the best rear gears . does my 82 have a dana 44 . cheers kev
Old Jun 28, 2023 | 02:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes alum if stock.
Old Jun 28, 2023 | 03:23 PM
GTR1999's Avatar
GTR1999
The best were GM or US Gear both gone now. Leaving nothing but imported. You spent large on the engine and trans and are keeping the Dana?
Old Jun 28, 2023 | 07:28 PM
USMC6113's Avatar
USMC6113
What would you recommend?
Old Jun 28, 2023 | 08:02 PM
GTR1999's Avatar
GTR1999
I would build a diff to the application. A DANA from an 80-82 wouldn't be one I would use, but that's just me and I do this every day.
Old Jun 28, 2023 | 09:59 PM
cagotzmann's Avatar
cagotzmann
Best depends on how you like to drive the car.
#1 if you like to step on the gas (full throttle) for 2-3 seconds and then off the gas gears 4.11 or 3.73 with the T56 close ratio.
#2 if you like track days then it depends on the track. reduce gear shifting. 4.11 & 3.73,3.55 a lot of shifting and may hit engine red line before the end of the straights.
#3 auto cross probabily doesn't matter , 2nd gear most autocross tracks with 3.08 or 3.36 or would be 3rd with 3.55, 3.73 , or 4.11
#4 street /highway driving 3.08 , 3.36 less shifting best gas mileage for highway, engine can easily deal with any diff gear.
most like #1.
my 78 is with a LS3 / 480 T56 Mag close ratio. Used for trackdays / street / highway. Have both 3.08 & 3.36 diff's both are fine.
Main question would be Based on GTR1999 how well it can handle the application use.
Old Jun 28, 2023 | 11:30 PM
Gale Banks 80''s Avatar
Gale Banks 80'
A general hot rodders rule is to use the factor of 10 for the first gear. In other words take 10 and divide it by your 2.66 first gear and you will get 3.75 so that will be your rear end ratio. If you have a small displacement engine with a high RPM you may want to use a factor of 11. If you have a large displacement engine with a low RPM you may want to use 9. And of coarse what are you going to use it for as mentioned above. I for see you doing an Iron Pumpkin conversion on your Dana 44.
Old Jun 28, 2023 | 11:42 PM
69L88's Avatar
69L88
Do you know how much HP and torque you have? From what I have read, you are north of 500 in both categories so if you are planning on transferring all of that to the rear tires, you need to think through all of the driveline components. The Dana design is inferior to the iron differentials used from 63-79 so swapping over to one of those, properly built to handle the higher power, is one step in the process. I emphasize properly built for a reason and that doesn’t mean a run-of-the-mill rebuilding service.
With your T56, I would recommend you shoot for a ratio in the 3.70 to 4.11 range.
Old Jun 29, 2023 | 01:46 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
And if you have an iron one built....let GTR1999 above (Gary) build it for you......and what else to get..I.E. Tom's axles, 1350 shafts...etc.....this is a good time to also setup the rear bearings at .001 to .003 if not done already......
Jebby
To 82 what rear gears
