Anyone know what this is?
Old Jun 28, 2023 | 06:56 PM
PhenyxC3's Avatar
PhenyxC3
Default Anyone know what this is?
Dropped out of the passenger side exhaust manifold.
Old Jun 28, 2023 | 07:08 PM
beachmusic's Avatar
beachmusic
Looks like your heat riser. A valve in your exhaust to help the engine warm up. Controlled by a thermoststic coil. Very restrictive. Most people eliminate it altogether or cut out the flapper as it looks like in your case.
Old Jun 28, 2023 | 07:38 PM
PhenyxC3's Avatar
PhenyxC3
Tossing it, thank you!
Old Jun 29, 2023 | 02:41 AM
Z51JEFF's Avatar
Z51JEFF
That's the POS I think that's causing my exhaust leak. Anybody know the correct part to replace this with?
Old Jun 29, 2023 | 07:46 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Most of the Vette vendors carry a heat riser delete spacer....get the studs, gasket and brass nuts too.....
1958-1974 Corvette 2" Exhaust Manifold to Pipe Spacer (GM Part 3750067) (zip-corvette.com)
Jebby
Old Jul 3, 2023 | 09:02 PM
Tech141's Avatar
Tech141
That was stuck in the 4/5's closed position on my '80. Found it when I replaced the stock exhaust with headers. No wonder my vette had NO acceleration when I bought it. Used to redirect hear towards the carb for the choke. Best tech at the time, but completely useless after 1982, IMO.
To Anyone know what this is?
