Double sealed needle roller bearing service
Old Jun 30, 2023 | 04:05 AM
XFire Performance's Avatar
0XFire Performance
Former Vendor
Default Double sealed needle roller bearing service
NEW SERVICE: If you are thinking about installing new bushings in your 82/84 CFI throttle bodies, we have a much better solution. We now provide a double sealed needle roller bearing service which gives a much smoother operation, you will never have to replace these again on your TBs. If you use boost, the roller bearings are good for about 15psi. Stop by the site in the Shop and check it out, you will not be disappointed.
