1/2" ARP wheel studs, 3"
Old Jul 5, 2023 | 11:33 AM
aaroncorvette's Avatar
aaroncorvette
Default 1/2" ARP wheel studs, 3"
Hi guys,
I'm going to change my wheel studs to 1/2" ARP wheel studs, 3". I changed the fronts to 7/16 ARP but on reflection I should have gone 1/2"
The ARP studs I had fitted to the front are -
https://www.summitracing.com/parts/ARP-100-7701 .486 knurl from memory. A machinist fitted them for me so i'm not sure what he did ie drill out further.
Anyhow I want to fit 1/2" 3" long front and back and i'm going to fit them myself. If anyone else has done this then which studs did they use and did they drill out? Also what is the hole size for a standard stud? I have a pillar drill and press now.
Aaron.
Old Jul 5, 2023 | 01:33 PM
aaroncorvette
Right guys
After bit more research i'm going to go with the ARP 100-7701 like I have on the fronts.
Thanks.
Old Jul 5, 2023 | 02:33 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Are you going to pull the rear stub axles and rebuild the trailing arms ? I think thats the only way to do it.
Old Jul 5, 2023 | 03:37 PM
aaroncorvette
There's a trick where you drill through the back plate. See this vid.
Old Jul 5, 2023 | 05:51 PM
GTR1999's Avatar
GTR1999
I use those studs a lot. Most times I machine the length to the size the owner wants to use. Few want 3". You have to check to make sure the knurl length is not longer then the flange thickness and sticks out or you will have rotor issues.
Old Jul 6, 2023 | 03:42 AM
aaroncorvette
[QUOTE=GTR1999;1606807795]I use those studs a lot. Most times I machine the length to the size the owner wants to use. Few want 3". You have to check to make sure the knurl length is not longer then the flange thickness and sticks out or you will have rotor issues.[/QUOTE
Hi GTR. Yes I saw your helpful thread on it. I will check this👍
i r just purchased the studs, calipers rebuild kit and new nipples. I will report back on progress.
Old Jul 6, 2023 | 07:36 AM
cottoneg's Avatar
cottoneg
I went to 1/2 inch when a rear rim and tire passed me on the right. My thoughts went to thinking what would have happened if the studs gave out durning a Time Trial.
I went to a machine shop and had them do the rear bearings at the same time.
Old Jul 7, 2023 | 10:06 PM
Pop Chevy's Avatar
Pop Chevy
Thats a good trick. I like that one!
Old Jul 9, 2023 | 08:25 AM
cottoneg's Avatar
cottoneg
It wasn't fun. I thought I was hit in the rear. I looked in the rear view mirror and saw nobody. Then the drivers side tire rolled past me. *DEEP SIGN*
Admittedly, I do run bigger than stock tires (335/35X17). So the stress is more than a stock tire and rim.
To 1/2" ARP wheel studs, 3"
