Is it open or is it closed?
Old Jul 10, 2023 | 07:07 AM
Z51JEFF's Avatar
Z51JEFF
Default Is it open or is it closed?
On a 75 the purpose of the exhaust heat riser valve is to close the flap in the exhaust when cold and open when hot but is it constantly opening and closing as revs rise and close as revs drop? It's my understanding it's either open or closed and doesn't operate like the butterflies on a carb. This is what the heat riser valve in doing on my 75 and it sounds like there is an exhaust leak at the valve. If I disconnect the air line to the valve the sound of the exhaust leak disappears.
Old Jul 10, 2023 | 07:25 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
The default for vacuum loss on a heat riser valve is for it to be stuck open but this happens about half the time.......
I urge you and anyone else to rid you life of that terrible thing and replace it with an open spacer........available from the Vette vendors.....
Even if I was restoring one of these cars to original condition......this would not be on the vehicle......
Jebby
Old Jul 10, 2023 | 07:31 AM
bmotojoe's Avatar
bmotojoe
Notice the finger stops on the heat riser...
When you pull the vacuum line off the actuator, the rod extends opening the heat riser valve...
When Vacuum is applied through the TVS switch, vacuum to the actuator will pull the rod up closing the heat riser valve.
Old Jul 10, 2023 | 07:49 AM
bmotojoe's Avatar
bmotojoe
Jebby
I agree,
This is something I watch for on any cold start.
The car doesn't leave the stall until I know for sure the TVS switch has changed state and the heat riser opens.
I'm still using the Hot Air Choke system so it does help reduce cold start runtime to about 3-4 minutes....
Old Jul 10, 2023 | 06:40 PM
Z51JEFF's Avatar
Z51JEFF
Here's the odd part,it fluctuates with RPM. Raise the idle it moves,it's not open or closed.
Old Jul 10, 2023 | 08:18 PM
bmotojoe's Avatar
bmotojoe
Post a photo of how it is plummd, you either have a faulty TVS switch or you have some vacuum hoses mixed-up or a combo of both.
The original TVS switch has what looks like 3 ports but one of them should remain open. It is the exhaust port.
Old Jul 10, 2023 | 08:58 PM
Z51JEFF's Avatar
Z51JEFF
I'm thinking the switch is bad. This car sat for 30+ years in a garage and I'm slowly bringing it back to life. I've followed the vacuum lines based on diagrams I've found online and the line seems to be going to the correct port at the bottom right of the carb. I'm going to replace the switch anyway so I'll know if this was the issue.
Old Jul 10, 2023 | 09:30 PM
bmotojoe's Avatar
bmotojoe
JMO, the way you describe what's happening you are plumbed to a ported or the EGR port. The EFE TVS switch should be connected to manifold vacuum...
Old Jul 11, 2023 | 01:44 AM
Bikespace's Avatar
Bikespace
Just wire it open until you can remove it, then remove any vacuum bits you don't need.
If you want to swing hard the other way, and get it to work as originally designed, this thread may help.
https://www.corvetteforum.com/forums...eat-riser.html
To Is it open or is it closed?
