71 coupe electrical question
Old Jul 10, 2023 | 02:26 PM
grumman41's Avatar
grumman41
Default 71 coupe electrical question
Not sure what the grey and purple wires go to? They are located at the front of the shift console, thanks!
Old Jul 10, 2023 | 03:13 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Gray is usually instrument lights and purple is neutral safety switch
Old Jul 11, 2023 | 03:10 AM
grumman41's Avatar
grumman41
Hhmmm, it looks like everything is hooked up in this area. This is an original un cut wiring harness.
Old Jul 11, 2023 | 08:50 AM
grumman41's Avatar
grumman41
I’m guessing since my car is a manual shift the purple wire isn’t hooked up to anything? Still not seeing where the grey wire goes to?
Old Jul 11, 2023 | 02:32 PM
wadenelson's Avatar
wadenelson
Grumman do you have a set of OSOEASY's laminated color schematics for your year?
They're worth their weight in gold.
http://docrebuild.com/oosoez/8971101.html
Old Jul 11, 2023 | 06:07 PM
grumman41's Avatar
grumman41
I don’t but I like the format, would like to have had one from the start of rebuild. The assembly drawings labels the grey as console ground but it has a plug type fitting. Hhmmm?
Old Jul 12, 2023 | 09:16 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
The gray wire is the PRNDL light connector for an automatic. It would not be connected on a manual transmission car. The purple and purple with stripe connector is for the clutch switch on a manual transmission. I don't know if it is a duplicate connector, or routed wrong. For the manual transmission it should be over by the clutch pedal.
Old Jul 12, 2023 | 02:38 PM
grumman41's Avatar
grumman41
Thanks for your input, I think I can get it sorted out now!
To 71 coupe electrical question
