No Hi speed on AC blower
If yes, it's located on the driver's side.
If your blower is not working on the High setting the first place to look is the 30 Amp fuse at the driver side fender.
Circuit #40 ORN wire from inline 30amp fuse (driver side fender area) is the common side of the high speed relay.
1) Place blower switch to high, if you have 12V on DK BLU wire at blower relay than the switch is good.
2) With blower switch to high check for power at the blower relay ORN wire, if you have 12V the fuse is good.
3) With blower switch to high check for power at the blower relay PPL wire, if you have 12V the relay is good.
Outside of wire issues there are only 4 components in the HI Blower system. 1) Console switch, 2) 30A Fuse, 3) Blower Relay and 4) Blower Motor.
If the blower motor is working on lower settings the motor is good.
I did not find a 30 amp fuse on the drivers side, but will look some more. There is a 30 amp in-line fuse (org wire) going to the relay that is good. I unplugged the relay switch and checked the connections on the harness as you said. #1 had 12V. #2 had 12V. #3 (purple) did not have 12V. Should I have checked it with the harness plugged in? It is a new relay. Blower does work on all lower settings. Thanks!
After doing a it more research looks like I do have the correct relay according to some parts sites I looked at. # JD191K16-12V
You stated that you had 12V at the ORN wire so that rules out the 30A fuse in the system being the problem. Next up is when the blower speed switch is placed in the High position it completes the circuit between (directs a 12V signal) the blower switch and the AC Relay via the DK BLU wire. When this happens the coil inside the relay is energized creating a magnetic field and pulling (closing) the contact that has 12V at the ready on the ORN wire. When this happens 12V is directed from the ORN wire contact to the PPL wire that feeds a full 12V to the blower motor.
When the blower speed switch is placed in the M1, M2 or LO position 12V is directed to the Resistor that reduces the voltage coming out of the Resistor to the Blower Motor causing it to operate at a lower speed.
With the Ignition switch in the run position, blower motor switch in the HI position you should have 12V at the ORN wire, DK BLU wire and PPL wire. If the PPL wire does not have 12V the relay is not closed. Have you verified the ground connection at the relay is good? This will prevent the DK BLU wire circuit from being completed.
