LT1 swap, 4l60 vs 4l60e
Old Jul 16, 2023 | 07:18 PM
Jeffwitty's Avatar
Jeffwitty
3rd Gear
Default LT1 swap, 4l60 vs 4l60e
I'm working on swapping a '93 LT1 and 4l60 transmission into my '79 Corvette. While looking at aftermarket harnesses I noticed all of them reference the 4l60e transmission. It was a lack of knowledge on my part, I purchased the engine and transmission without realizing the difference that e makes. However it has set me back a bit as I'm no longer certain about half the information I've gathered.
So my question is this: Should I consider purchasing a 4l60e transmission and sell off the 4l60? Or could a 4l60 be used without much consequence?
Old Jul 16, 2023 | 07:39 PM
Eric P's Avatar
Eric P
4L60E with a aftermarket ECM to control it , you can adjust shift points full throttle, adjust Lockup Torque Converter and just have a better transmission. If you go 4L70 you can use the TCC to split gears because the Lockup clutch inside the Converter is way more durable than a 700 , 4L60e and 4L65E , below is the Controller I would use
https://www.usshift.com/usq4.shtml?g...iABEgLlOfD_BwE
Old Jul 17, 2023 | 12:07 PM
lionelhutz's Avatar
lionelhutz
The LT1 PCM to use is the 94-95. The 94 4L60e is a 1-year only transmission without the PWM solenoid for the TCC. The 95 is also a 1-year only transmission with a specific downshift solenoid.
I run a LT1 with the PCM flashed for a 95 and it runs a 96 4L60e. It has worked fine for me, but some people say this can't work.
Old Jul 19, 2023 | 11:50 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You can use the 4L60...it is a 700r4......same trans. Just pay carefull attention to your throttle valve cable...it is the lifeline of these transmissions......
Jebby
Old Jul 22, 2023 | 11:01 PM
JimmyHill's Avatar
JimmyHill
The 4l60(700r4) will work fine if you use a harness meant for a stick car. Only a switch and relay are needed to manually control the torque converter lockup.
https://www.motortrend.com/how-to/ho...hout-computer/
Heed Jebby's advice about the TV cable though. I know a few people that fried fresh 700r4 and 200-4r rebuilds because they screwed up the adjustment at install.
Old Jul 23, 2023 | 09:30 AM
lionelhutz's Avatar
lionelhutz
Since you are already putting electronics on the engine the e transmission opens up so much for shift curve tuning it's way better to use. Don't like the shifting curve or TCC lockup - just change it in the tune.
To LT1 swap, 4l60 vs 4l60e
