Replacement Exhaust / Header Fit Guidance?
If I get a complete exhaust system from one of the vendor catalogs, will it bolt straight to a set of headers? If not, how much cutting, welding etc. has to be done? I'm running a 350 small block with the TH400 automatic.
(Its easier and cheaper for me to order an entire system than to take it to a muffler shop, the body is still off the frame and I'm trying to get as much done as possible with the body off).
Any suggestions for combinations or guidance for what I have to do would be appreciated.
Regardless of which brand of exhaust you buy, you'll probably find that you need special cut and fit pipes for the header attach end and through the frame crossmember.
On my system (with Flowtech headers) I had to create special reducers at the header flanges to route around the 400 tranny.
Here's a muffler flow chart I clipped from an earlier thread.
OEM..................................... ........................................ ...225
Gibson SuperFlow 788200.................................. ............311
TTS Bullet Cat Converter............................... ..................324
Flowmaster 40 series 42540................................... .......352
Flowmaster 50 Series.................................. ...................362
Flowmaster 40 series 43040................................... .......392
Dynomax Super Turbo................................... .................410
Flowmaster 62631................................... .......................435
Carsound Cat Converter............................... ..................436
FLP Cat Converter............................... ............................440
Edelbrock Victor 5535.................................... ..................562
Flowmaster 40 series 435409.................................. ........576
Edelbrock RPM series 5511.................................... ..........579
Flowmaster Delta Force Racing 54040-10........................634
Edelbrock 304 series 5560.................................... ...........640
Edelbrock Gen App 5505.................................... ..............708
Dynomax Race Magnum Welded 17216...........................711
Borla XR-1 40600................................... ..........................836
Borla XR-1 40615................................... ..........................854
Dynomax UltraFlow SS 17263................................... .......1000
Dynomax Race Magnum Welded 17218...........................1000
Borla XR-1 40575................................... ..........................1100
Dynomax UltraFlow............................... ...........................1133
Edelbrock Victor 5537.................................... ..................1400
Borla XR-1 40450................................... ..........................1400
Borla XR-1 40741................................... ..........................1450
Dynomax UltraFlow SS 17296, 17268..............................2200
Dynomax Race Magnum Welded 17220, 17224...............2200
Dynomax Race Magnum Welded 17225...........................2600
I replaced my exhaust system (2.5", but my original exhaust in 68 was 2.5") and installed flowmasters. With the elbows it's a lot of parts. The flowmaster mufflers are a little larger than the stock mufflers so it is a tight fit. I have an extra set of front exhaust pipes that are specially cut to fit with headers. I just haven't installed the headers yet. MJ
