corvette gas cap
Old Jul 25, 2023 | 06:53 PM
Bills17n72's Avatar
Bills17n72
Default corvette gas cap
hay friends ,the gas cap on a 72 is it the same as the 74 , , will it fit and lock down the same on both cars? thanks Bill
Old Jul 25, 2023 | 07:03 PM
gbvette62's Avatar
gbvette62
Yes, 70-74 Corvette unvented gas caps are all interchangeable.
Old Jul 25, 2023 | 08:44 PM
Bills17n72's Avatar
Bills17n72
this is a vented one , , it should still fit right , it fits on my 72?
Old Jul 25, 2023 | 09:36 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I think that all '63 to '74 caps are interchangeable. They were marked VENTED up until 1970 at which point they were marked SEALED. In 1970 GM cars got the charcoal canisters to capture raw fuel vapors to eliminate it from escaping to atmosphere.
Old Jul 25, 2023 | 09:54 PM
Bills17n72's Avatar
Bills17n72
thanks 67:72!!!
Old Jul 25, 2023 | 09:57 PM
gbvette62's Avatar
gbvette62
Correct, while there were some differences in appearance of some year caps, all 63-74 caps are interchangeable. The 63-67 convertible filler neck was also used as the filler neck for all 68-74 Corvettes (the 63-67 coupe neck is taller and was only used on C2 coupes).
If you have a cap marked "vented" you have the wrong cap, but it will still go on your 72.
Old Jul 26, 2023 | 12:00 AM
barkingrats
Just to add one more detail on the cap recommendations. If the charcoal canister system is still in place and operational then the SEALED cap needs to be used. If the system is inoperable or non-existent, ensure the tank ports have been sealed off and use the VENTED cap.
Using the wrong cap can lead to excessive fuel vapor odors because the design of the system for each has been compromised.
Old Jul 26, 2023 | 04:15 PM
dennis's Avatar
dennis
Only California 70's had na9, (eec). My 2 70's both have sealed caps.
Old Jul 27, 2023 | 06:54 AM
Papy thumper's Avatar
Papy thumper
Cruising
Default An other solution
There's an other solution if you don't care about original system. On my 77 i cut the To canister hose and fix it behind the left rear wheel with a mini KN filtre. No fuel odor and a more simple stuff.
To corvette gas cap
