exhaust ID/OD: questions
Old Jul 27, 2023 | 04:07 PM
rgouette's Avatar
rgouette
Default exhaust ID/OD: questions
I've got a new set of Patriot side pipes (H1060)
I'm looking to understand better, what I need to connect to them.
They're spec'd as having a 2" inlet, but it doesn't measure at 2" for me, but I'm also not an expert..
I took accurate measurements today, and here's what I found for the ID(using ruler, and a digital caliper):
Old Jul 28, 2023 | 08:29 PM
righthanddrive's Avatar
righthanddrive
I just measured a 45 degree elbow for my exhaust , and it measures 2.25" on the inside of one end and 2.25" on the outside of the other +/- 10 thousand for easy slip on fit..
I think they sent the wrong ones. Double check the paperwork and description. I also bought an exhaust expansion tool at harbor freight for future issues .
Good luck.
Ed
Old Jul 28, 2023 | 08:57 PM
rgouette's Avatar
rgouette
Good luck.
Ed
Well, honestly, I’d be happy if they were anything north of 2 inches, since the collector is 3 inches.I’d rather mate up to larger than smaller in this case.Good idea on the harbor freight thing, I’ve got a big harbor freight right in town.Might not be a bad idea to have some exhaust tools handy
Old Jul 28, 2023 | 09:14 PM
71 Vert LS1's Avatar
71 Vert LS1
Exhaust tubing is always measured on the outside diameter. When I'm doing an exhaust from pieces and parts I take the parts as needed to a local muffler shop and have them sneak up on the slip fits. They don't charge me a nickel.
Old Jul 29, 2023 | 09:01 PM
rgouette's Avatar
rgouette
ok, here's the new OD reading I took just now...
That look right to you guys for an inlet?
Old Jul 29, 2023 | 09:59 PM
righthanddrive
I think if you measure the inside of the tube, you will find it's 2 1/4". That way the next part will slip into that one if you are using 2 1/4" tubing.
To exhaust ID/OD: questions
