72 350 4 speed mini starter ?
Old Aug 3, 2023 | 11:48 AM
ckirsch100's Avatar
ckirsch100
Active Streak: 90 Days
Default 72 350 4 speed mini starter ?
I am trying to replace my original gm starter with a mini starter.The car has headers and the starter is a real bear to take out.After searching forums I thought the AcDelco 337-1022 mini with the staggered bolt pattern would fit with no shims necessary.This starter gets hung up in the opening of the bell housing inspection plate.This starter has an aluminum nose cone.I guess maybe it would work with an auto trans.???I would like to find a direct fit Delco mini if possible.Any and all help is appreciated.
Old Aug 3, 2023 | 12:08 PM
Mdbirk's Avatar
Mdbirk
I had a similar issue, I bought this on Amazon. Went straight in with no shims and works great
Amazon Amazon
Old Aug 3, 2023 | 12:37 PM
ckirsch100's Avatar
ckirsch100
Did your original starter have the staggered holes?Did you have to machine the aluminum mounting block on the new starter?I had a similar starter and it hit the oil pan lip.
Old Aug 3, 2023 | 01:25 PM
Mdbirk's Avatar
Mdbirk
My car had a mini starter when I bought it. After 20 some years it needed to be replaced. I bought 2 that didn't work and some one recommended this starter to me on Amazon. It has 3 different clocking positions, I clocked it to clear the oil pan and went right in no problem.
Old Aug 3, 2023 | 01:40 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
I use and recommend the CVR 5323......IMHO there is no better.
Jebby
To 72 350 4 speed mini starter ?
