Paint Stripper?
What brand of stripper is recommended?
Is it a slow process?
Can I use the same stripper for the urethane and fiberglass?
Should I attempt this, or just pay the price?
Will this hurt the gel coat?
Is soda blasting the better way to go?
Any tips or stories are welcome.
:confused:
I think the latest technique is media blasting, using plastic pellets.
I haven't done either, so I have no advice, but I will be needing information as well once I decide to paint the C3.
Many others have used this product successfully but I'm afraid it will take you much longer than 2 days. If you worked at it for a full 8 hours a day I think you would be looking at a full week's worth of work.
I've got cars that I stripped in the 70's and don't have paint issues with them now. It is important to use the proper strippers. There may be some others that work well, but some that are too strong and will damage the glass. As far as the statement about the gel coat, you don't have to worry about that, because no Corvette has EVER had gel coat applied at the factory..........not ever.
There are two products that I've used and like. One is the Redi Strip that's frequently sold at car shows. It's water like in consistency and is applied with a spray bottle. The second is a product made by Dupont and sold at body shop supply stores. I don't recall the stock number, but it's in a grey and white can.
The process is simple. Take strips of duct tape and tape everywhere you don't want stripper to run, like door cracks, hood cracks, etc. Remove everything the bodyshop is going to remove anyway. Do a relatively small area at the time, like the top of a fender, half the deck, etc. If you're using the brush on type like the Dupont, make all the brush strokes in one direction. This does something with oxygen molecules that I don't understand, but it does make a difference. Let the stuff start wrinkling the paint and use a plastic squeegie, like Bondo is applied with and scrape it off. DO NOT USE METAL SCRAPERS OR RAZORBLADES. The strippers will take paint but not primer. After the car is down to the primer, use laquer thinner and scotch brite pads to wash it to bare fiberglass. This can be more labor intense than the paint itself was. Dried paint & stripper mixed is harder to remove with more stripper than the original paint was., so get it all off in an area and watch were it runs. I usually put multiple layers of newspaper down or better yet the rosin paper like most building supply stores sell is a good floor covering. Also tape paper across the tires because the stuff will drip off the fenders and make a mess there too. One other thing I've done on the last 2 is get a sheetrock mud tray at the building supply and scrape the paint & stripper mess into it. Don't forget the rubber gloves also, that stuff burns on your skin. Multiple layers of laytex will work if changed real frequently or the black chemical type will last much longer. I tried Playtex gloves and they don't last much longer than the latex and cost 50X more. It is time consuming, especially in the door jamb type areas, but not overwhelming if you have a little patience.
Edit: a couple more thoughts: Avoid aircraft type stripper....it will damage the glass. The time involved will depend on what kind of paint is on the car and how many times it's been painted. I just bought an original paint 62 fuelie and washed one quarter and one door to clean glass in about an hour and a half to 2 hrs, (excluding door jamb and trunk trough. Most of the time spent on primer scrubbin'. Original paint = easy, catalyst type paints such as BB/CC are much harder, and in the unlikely event that somebody did it with Imron, you've got a mighty tough job ahead. If the car has catalyst type paint or a lot of any type, I'd hit it with real course paper on some type of orbital sander, just to cut the paint, not to get anywhere near the fiberglass, and this is REAL important. DON"T GET ANYWHERE NEAR THE GLASS with the sandpaper, The idea is to just scratch up the paint. I've seen cars that people tried to sand paint off of. They invariabley change a body line, get one too sharp, or get something wavy. Don't do it. One other thing, stripper will soften body filler, so previous repairs will require attention.
[Modified by Solidlifters, 11:19 PM 1/20/2003]
I stripped a couple of parts with stripper , but the rest I'm doing with razor blades.
You cut the paint off and use a shop vac to suck up the little chips. No mess, no cleanup.
It sounds scary, but I did less damage with the razor that with the stripper. It's less messy, and more accurate.
My car had sat outside 20 years. Cap'n Lee's was used. 2 of us stripped it in 3 nights, about 3 hours a nite, including laquer thinner washing. The hood, however, had been stored in the garage the entire time. Took a LOT longer to strip, and the bottom layer was much tougher to remove. I think the UV rays had helped break down the paint by sucking out the binders and resins.
There were 2 repaints on the car, it had no assembly-plant-applied paint, just a gray primer (shipped in prime).
If a razor blade will peel it off, there were adhesion issues already present.
And I would NEVER DA a corvette. The time "saved" will be reinvested many times over priming/blocking/priming/blocking/priming/blocking......
We've got a (used to be)nice '58 at the shop that some genius decided to strip with a DA and 80 grit. :nonod:
[Modified by a454corvette, 11:26 PM 1/20/2003]
but each his own, some like the blade, some media blasting, some chemical strippers...
Just like I thought, messy and time consuming. I have read so many pro's/cons about strippers/sanding/media blasting, and I feel stripper is the way to go.
I have heard plastic media blasting will remove the gel coat, I have heard of people using baking soda, and supposedly it is okay.
Sanding is scary also because you don't want to mess up the lines of the car.
I guess the paychecks will dictate whether or not I do it myself...
[Modified by lil ski, 9:39 PM 1/21/2003]
