Crossfire keeps stalling when cold
Old Aug 9, 2023 | 09:33 AM
DarrellD23's Avatar
DarrellD23
Default Crossfire keeps stalling when cold
Hi Guys, 1982 crossfire engine 26000 miles. No problem until a few days ago. The engine will start when cold and immediately stall. If I keep pumping the gas it will continue to run until I stop pumping. If I get the rpms up and hold the gas steady it will stall. If I keep pumping and get the engine to warm up a while it will eventually idle. Once I get the engine to run without stalling by warming it up I can drive the car with no problems. Runs drives and accelerates to 80 mph with no hesitation or problems. Starts fine and idles fine when warmed up. Any ideas?
Old Aug 9, 2023 | 01:08 PM
wwiiavfan's Avatar
wwiiavfan
I don’t know anything about crossfire, but sounds like the ecm either isn’t getting the temp signal from the motor (bad sending unit, bad wiring), or ecm is getting the signal, but not acting on it correctly (probably requires a deeper dive into the ecm).
Im sure someone here will have specifics for you, but I’d start by looking at the temp sending unit and wiring.
Old Aug 9, 2023 | 02:57 PM
DarrellD23's Avatar
DarrellD23
WW, that's one of the things I was thinking. Update when I got home today I went to start the car it started no problem check it out for half hour Cruise no problem. Turned it off and on no problem. Let it cool down try again no problem. I can see this is going to be an intermittent thing that's going to drive me crazy.
Old Aug 9, 2023 | 08:21 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
temp sender system is a good thought.
a few 82 members here and hopefully will add some possibilities.
remember underneath it all, it is a small block and
needs the same things to run.
a good scanner will tell you what ecm is seeing from the sensors.
sorry, I don't know which one to get.
Old Aug 9, 2023 | 09:56 PM
DarrellD23's Avatar
DarrellD23
Second update, went to start it 3 hours later and it won't start, it ran for about 10 seconds and then just stalled. Repeatedly stalled when trying to start after that. Went again 3 hours after that and still won't start. I will have to try to find some time to start looking for the problem.
Old Aug 9, 2023 | 10:02 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
So, are you getting a CEL? If so, have you checked the codes? Do you know what your fuel pressure is right now? It could be a few different things to also include the CTS sensor or the ECM. Do you have a GM service manual? If so, start troubleshooting with that manual. It has a lot of good things in it for fuel related issues.
Old Aug 9, 2023 | 10:14 PM
DarrellD23's Avatar
DarrellD23
Originally Posted by Buccaneer
So, are you getting a CEL? If so, have you checked the codes? Do you know what your fuel is right now? It could be a few different things to also include the CTS sensor or the ECM. Do you have a GM service manual? If so, start troubleshooting with that manual. It has a lot of good things in it for fuel related issues.
Hi Tom, thanks for replying. We spoke before, I'm the guy in Canada that found the brand new Renegade and might sell it but that's another thread. Strange thing is there is no cel coming on and yes it is operational. I have to get a pressure gauge. Are yours back in stock yet? Yes I have a manual and will be using it.
Old Aug 10, 2023 | 11:02 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
If it is doing it stone cold then it is in open loop.......which the ECM is not yet getting feedback.......so my money is on fuel pressure.......CFI/TBI runs fat in open loop....if your pump is on the way out and is pushing, say....11psi...it might not be enough.....or the reg is not calling out enough pressure.
Anyway....start there.
Jebby
Old Aug 10, 2023 | 04:34 PM
Fly skids up!'s Avatar
Fly skids up!
^This!
Old Aug 11, 2023 | 01:13 AM
Buccaneer's Avatar
Buccaneer
Reply to your email sent.
Old Aug 11, 2023 | 12:43 PM
DarrellD23's Avatar
DarrellD23
Thanks for the replies, I'll let you know what happened when I actually figure it out.
To Crossfire keeps stalling when cold
