Poly To Rubber Trailing Arm Installation
Old Aug 13, 2023 | 07:32 PM
Gioviannia90's Avatar
Gioviannia90
Default Poly To Rubber Trailing Arm Installation
I am in the middle of changing out the 10 year old poly TA bushing that crumbled into a thousand pieces. I have removed the passenger side TA and prior to drilling out the retaining flare, noticed some shim washers. The new rubber bushings only have the beveled washer. My question is, were these shims to make the poly bushing the same width as an OE bushing? When I reinstall with rubber, will my shimming change because they had these shims on the poly bushing?
Old Aug 13, 2023 | 07:49 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes.
to all questions.
you can measure the poly width, and should.
then when rubber bushings are compressed and flared, measure width.
do math, then adjust alignment shims to compensate.
Old Aug 13, 2023 | 08:05 PM
interpon's Avatar
interpon
I do not recall usng shims with rubber so i would say no.
i took some measurements in this thread
https://www.corvetteforum.com/forums...nd-advice.html
Old Aug 13, 2023 | 08:10 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
no shims on rubber.
Old Aug 13, 2023 | 08:41 PM
Gioviannia90
Yes I agree no shims on rubber. But I wonder if I will need to adjust the shim thickness for the actual TA shims that go on the side. Service manual simply says to make sure you put the same TA shims back into the same location.
Old Aug 13, 2023 | 08:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
after you measure poly width and then mounted rubber bushes, you will know.
chances are the will be different.
when the rubber is wider, then remove equal sized shims from inner and outer
(trailarm) mounting the amount of difference from poly.
if rubber is thinner, add equal amount of shims to inner and outer.
once you have the width difference between the 2 bushes styles you will know.
extra shims will be needed to do this.
Old Aug 14, 2023 | 08:02 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Service manual MAY be referring to the toe-in alignment shims, that you removed, when you took the TAs out.....
Old Aug 14, 2023 | 08:15 AM
Gioviannia90
Yes that is what the service manual is referring to.
Old Aug 14, 2023 | 10:03 AM
interpon's Avatar
interpon
i would center the arm for alignment..pack in shims.. and have aligned with a shim pack with various sizes for alignment shop.
To Poly To Rubber Trailing Arm Installation
