Seriously, brake booster removal
Old Aug 15, 2023 | 09:10 AM
garkahn60's Avatar
garkahn60
Default Seriously, brake booster removal
It's really not possible to remove the power brake booster on a '69 is it?
I cannot access the upper left bolt under the dash. So far I have removed the steering column, upper and lower dash pads and I still can't hardly get a glimpse of that little F'r. I have read post and watched YouTubes were its been done. I think most, if not all of the successes have been on automatic cars. My car is a manual. Maybe I need to remove the clutch pedal assembly???
Any sympathy would be appreciated.
Old Aug 15, 2023 | 09:28 AM
69FASTFUN's Avatar
69FASTFUN
I replaced the booster on my 69 with 4 sp I can't remember it being real difficult. I didn't remove the steering column.
Old Aug 15, 2023 | 10:48 AM
69autoXr's Avatar
69autoXr
It is possible with patience, and the right combination of extensions and a swivel socket.
Old Aug 15, 2023 | 10:58 AM
Greg's Avatar
Greg
Just another Corvette guy
^^^^This
Old Aug 15, 2023 | 11:48 AM
Sayfoo's Avatar
Sayfoo
Remove the seat, put down a folded blanket for padding, and lay on your back. Use a combination of long sockets, long ratchet extensions, swivel, etc.
The hardest part was getting back out of the car after 15 minutes on my back.
Old Aug 15, 2023 | 01:08 PM
Danish Shark's Avatar
Danish Shark
+1 on removing the seat. It is really easy and gives you a lot more room.
Old Aug 15, 2023 | 06:59 PM
Mooser's Avatar
Mooser
I remove the seat to change the radio station
Automatic so....
A set of extensions. IIRC only needed the swivel (with a balloon sleeve over it) for the top inside one and a wobble end extension was good enough for the others.
(then went hydroboost and installed studs into the engine bay so I'll not have that problem anymore)
M
Old Aug 16, 2023 | 02:58 AM
Tuna Joe's Avatar
Tuna Joe
Too funny!
I tried the other day to remove the booster on my 69 also.
got all the bolts out but one.
I thought the same thing! Damn near impossible!
Ive got one bolt left!
Old Aug 16, 2023 | 09:32 AM
garkahn60's Avatar
garkahn60
I do have the seat out. I spent a day on just trying to access that bugger. I'm not one to give up. I think I'll take the body off the frame next and see if that helps.
Old Aug 16, 2023 | 09:40 AM
Mooser's Avatar
Mooser
Can't hurt
M
Old Aug 16, 2023 | 12:01 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
M
Old Aug 16, 2023 | 12:25 PM
OldCarBum's Avatar
OldCarBum
If I remember correctly I removed the seat, steering column and used an open end/box end wrench.
It took a while but I got it done.
My radio was already out.
Old Aug 16, 2023 | 01:46 PM
Tiger Joe's Avatar
Tiger Joe
I've heard lots of folks say the booster is one of the hardest jobs on the c3 vettes. I dunno i just dont get it? i changed one on my 68 auto in probably 20 min. my 4 speed was a bit more challenging but nothing crazy.
different length extensions, swivel sockets, and a fine tooth ratchet worked for me. i didnt remove anything
Old Aug 16, 2023 | 02:28 PM
pspicci's Avatar
pspicci
I'll take the brake booster over the heater core anyday.
Pat
Old Aug 16, 2023 | 05:42 PM
John 65's Avatar
John 65
77 auto car here. Took out the seat and left the column alone. I was able to get to that bolt with a short stubby ratchet and a deep socket. Didnt really have the room for a universal.
I used the original clip again, didnt like the look of the new repro.
To Seriously, brake booster removal
