Diagnosing courtesy light issue
Old Aug 15, 2023 | 01:42 PM
krazeehorse's Avatar
krazeehorse
Default Diagnosing courtesy light issue
Lamps didn't go out on my 68 with both doors securely closed. I rotated the headlamp switch and they were still on. So I pulled the bulbs to keep from draining the battery. So my plan is to pull the door jamb switches one at a time and remove the wires from them. If the lights go out then that switch was the one that failed, correct? If disconnecting neither resolves the issue then it just about has to be the headlamp switch? Am I thinking correctly?
Thanks, Kevin
Old Aug 15, 2023 | 01:50 PM
C3 Stroker's Avatar
C3 Stroker
Before pulling the jamb switches, make sure the left side lamp socket bracket is grounded. I had the same problem when mine got accidentally kicked loose.
Old Aug 15, 2023 | 01:59 PM
krazeehorse
Thanks Stroker, I will check that out.
Old Aug 15, 2023 | 02:28 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Make sure the door switches are closing enough. Push them in by hand to test them. My one door has a metal bracket that helps push the switch in farther. Not sure if that is factory installed or not.
Old Aug 15, 2023 | 02:30 PM
Eliredandblack's Avatar
Eliredandblack
Also have a helper and yourself push the both switches plunger all the way in. On my 73, I had to use small rubber pads to get the door ajar switches to be pushed in far enough to turn off the indicator light. Do the easy stuff first!
Old Aug 15, 2023 | 02:56 PM
krazeehorse
I'm all about the easy button Eli. Thanks for the tips all!
Old Aug 16, 2023 | 12:42 PM
wadenelson's Avatar
wadenelson
Doors on my '68 have two switches apiece. Don't know which is which. The Door Ajar feature works, the courtesy lights don't.
Be aware... the rear switch, below the striker on the door... can be accessed via a removable panel in the wheelwell. I opened that up oe day wondering WTH was in there and
found non grommeted, unsleeved wires passing through metal bulkheads. Great recipe for chafing.
AND a lot of mud and gravel...
To Diagnosing courtesy light issue
