Shifter/transmission issue
Old Aug 20, 2023 | 10:54 AM
krazeehorse's Avatar
krazeehorse
Default Shifter/transmission issue
So I go out to the garage this morning where I back my car in (68 roadster). I start it and put it in first. As I release the clutch the motor pulls down like I have a freight train hitched on to me. It won’t budge. No e-brake. I run the shifter through the gears including reverse and get the same results. I put it in neutral and slowly release the clutch and the car eases backwards. So I shut it off and moved shifter through all its positions and start it back up with the same results. There is no grinding or any strange noise. Am I stuck in reverse and when I shift it’s in two gears at once? Doesn’t seem likely, especially with no funky noises. HELP!
Old Aug 20, 2023 | 11:18 AM
Bikespace's Avatar
Bikespace
2 gears at once is quite possible.
I don't recall the steps, but hopefully someone will post a link. Do you have a way of raising the car onto jackstands and taking a look at the transmission linkage bars? Setting the levers manually (with a wrench or whatever) should solve this problem, at least temporarily.
But step 1 is to get under the car, safely.
Old Aug 20, 2023 | 11:23 AM
krazeehorse
I kinda figured that’s where I was at. We have the stuff to do that safely. Not tackling it today. One night after work most likely.
Old Sep 17, 2023 | 06:47 PM
krazeehorse
Well I got the original problem resolved but it happened again. Is there a shifter rebuild kit that has everything you need or am I barking up the wrong tree? I hate to buy a new shifter but I don’t want to cringe in fear every time I use reverse.
Old Sep 17, 2023 | 08:45 PM
Bikespace's Avatar
Bikespace
So what was the problem, and how did you fix it? Did you happen to take any pictures while you were down there?
If you have a Hurst shifter, there are two different kits with plastic or metal bushings (pit packs) that you can use to eliminate some of the slop. I don't think they work on the stock linkages, though.
Old Sep 18, 2023 | 09:25 AM
krazeehorse
No pics. My brother used a pry bar and moved the reverse lever back forward into the neutral position. It is a factory shifter with reverse lockout.
Old Sep 18, 2023 | 11:30 AM
MelWff's Avatar
MelWff
The problem is usually caused by the bolts holding the shift levers to the shafts coming out of the case loosening up. Place everything into neutral and tighten the bolts.
Old Sep 18, 2023 | 11:41 AM
Z0Tex's Avatar
Z0Tex
The Corvette parts houses (Zip, Corvette Central, etc.) sell shifter rebuild kits that include new interlocks to help take up the slop that develops in the shifter mechanism over time. Try tightening the bolts as @MelWff suggested, but if it happens again a shifter rebuild may be in order.
https://www.zip-corvette.com/68-4-sp...build-kit.html
https://www.volvette.com/SH005N-68.html
https://www.corvettecentral.com/c3-6...fter%2f1968%2f
Old Sep 18, 2023 | 01:34 PM
krazeehorse
Thanks guys. I will check the bolts holding the arms on.
Old Sep 19, 2023 | 08:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Readjust the shifter detents with the "tongue" or "blade" tool as per the factory assembly manual too.......
Jebby
Old Sep 19, 2023 | 09:54 AM
krazeehorse
Jebby
Will do....thanks.
To Shifter/transmission issue
