I replaced my oil line with a braided line and the adapters that came with the kit didn't include a 90 that would help me in that tight space. If I use the adapter and 90 supplied, it extends about 1.5" off the gauge. I'm trying to tuck this in tight, but can't find a the adapters I need to do this.
As anyone done this and if so, what configuration of adapters did you use. I just replaced the carpet and added Vintage AC, so I need to avoid an oil spill and I'm not sure how much room I'm going to have behind the gauge now.
The gauge fitting is a different critter. Some have had success using a npt fitting and some sealant or just driving it into the threads on the gauge and it seals
Here's one method of dealing with it https://www.corvetteforum.com/forums...arts-list.html
I made a fitting to suit my needs but that's probably not much help to you
M
