Throttle linkage bushings
Old Aug 23, 2023 | 05:51 PM
frankenbro's Avatar
frankenbro
Default Throttle linkage bushings
Has anyone put a throttle linkage bushing kit in they’re crossfire injected car?
Old Aug 23, 2023 | 06:19 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
"throttle linkage bushing kit"? You mean throttle shaft bushings?
Old Aug 23, 2023 | 06:29 PM
Fly skids up!'s Avatar
Fly skids up!
Yes I've have.
https://www.corvetteforum.com/forums...m-odyssey.html
Old Aug 24, 2023 | 08:21 AM
frankenbro's Avatar
frankenbro
I’ve heard that it could be the reason my car skips a beat in high gear randomly. Is that why you installed it?
Old Aug 24, 2023 | 11:43 AM
Fly skids up!
I rebushed my throttle bodies because they wouldn't return to idle.
Old Aug 24, 2023 | 01:50 PM
frankenbro's Avatar
frankenbro
A friend thinks this could be causing my problem. It doesn’t seem that loose. It seems to work fine but I don’t know what’s happening with it when at 40mph it skips.
Maybe I’ll try the Egr valve and check the fuel pump. Tricky tricky
To Throttle linkage bushings
