PS Control valve question
It's a 47 year old, 100 thousand mile power steering control valve that has never leaked. Note the 12 point bolts that hold the housings together. Also please note on the right hand side that no shield of any kind is present.
Photo from above manual, note no shield.
Exploded diagram from same factory manual. Note no shield shown. Also note, number 5, valve mounting bolts are 12 point head bolts in this diagram.
Replacement control valve. What the Blank is this shield? Why it it there? When did this start and why? Note garden variety 6 point bolts holding the housings together as well as retaining this shield.
Shield looks to make getting a line wrench on the lines far more difficult.
I am replacing this part as the ball stud and socket are worn. One can purchase a seal kit but the stud and socket seem to be made of unoptainium.
Anyone have a clue why this sheet metal shield has been added? Other than being in the way.
https://www.corvetteforum.com/forums...rol-valve.html
My 77 was missing it also, but have seen other 77's with them. Found one, would like to bolt it on but dont want to open a can of worms in doing so.
it doesn't appear to belong.
Ball and stud kit
BTW - Do not overtorque the 2 valve assembly screws. The CSSB tutorial shows "60 ft-lbs" but that is probably way too tight.
I've got this new one now, with a good stud and seats. If it gives me issues I can likely make one good one out of the two. As per the shield. It just looks in the way to me, I think I'll lose it.
thank you for the answers.
