Power steering fluid leak
Old Sep 1, 2023 | 05:11 PM
ALLEN007's Avatar
ALLEN007
Default Power steering fluid leak
Got a couple drops of fluid coming from the two fittings I'm pointing too. Should there be tape on the threads? Doesn't look like there is any.
Old Sep 1, 2023 | 05:46 PM
sunflower 1972's Avatar
sunflower 1972
I would just snug them up a little with a line wrench, of course.
ALLEN007's Avatar
ALLEN007
I checked. They are tight.
Old Sep 1, 2023 | 05:54 PM
sunflower 1972
The hose ends are an inverted cone. The PSCV hose openings are cone shaped. Therefore, you need to JUST GENTLY SNUG the nut fitting as the cone shape prevents the hose from leaking, not the threads.
Old Sep 1, 2023 | 06:29 PM
ALLEN007's Avatar
ALLEN007
Yes, looks to be pipe threads. Pipe threads should have teflon tape on them (I think). It is leaking where the threads screw in to the housing. Guess it can't hurt to put some on. Thanks.
Old Sep 1, 2023 | 06:44 PM
sunflower 1972
But, they're not pipe threads.
Old Sep 1, 2023 | 07:16 PM
81c3's Avatar
81c3
I didnt use any teflon tape on mine.... theyre all dry. Maybe someone overtightened yours at some point and now the part where the line seats is a little distorted or worn. You will probably need new hoses....
Old Sep 1, 2023 | 09:20 PM
71 Vert LS1's Avatar
71 Vert LS1
I haven't had to use them but I know for brake line inverted flares they sell brass washers that are formed to the 45 degree to help seal rough fittings. Don't know where they get them but I bet a google search might get you a hit.
Old Sep 1, 2023 | 09:58 PM
n2h2o2's Avatar
n2h2o2
Do not use teflon or pipe dope, or anything like that....These are flare fittings, and the seal comes from the cone seating into the flare in the tubing. The threads are not where it seals.
Make sure your threads are completely clean and that there are no deformities in the flare or the cone...and try again...
Leaking is usually because of a bad flare (split) or over tightening.
Old Sep 2, 2023 | 03:12 AM
Eliredandblack's Avatar
Eliredandblack
Try loosening the fitting, then retighten, it worked on my car. If the hoses still leak, you should get new hoses. With new hoses, use a flare wrench and tighten only a bit. Start the engine and if you see a leak, tighten the fitting a little, until the leak stops. Be sure to thread the fitting with out cross threading.
Old Sep 2, 2023 | 04:47 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I don't know about this "Gently snug" the lines suggestion. I tighten the living #@$%#@ out of them so they don't leak. And then they don't!
Old Sep 2, 2023 | 06:15 PM
ALLEN007's Avatar
ALLEN007
Probably a dumb question but when I remove them will the ps fluid start pouring out. Or just a little.
All the hoses are fairly new from the previous owner. Could be he over tighten them
Thanks for all the help!
Old Sep 2, 2023 | 08:11 PM
4-vettes's Avatar
4-vettes
When you remove them yes all your fluid will fall out. Slowly if you leave the cap on the reservoir. Much quicker if you remove the cap.
Old Sep 3, 2023 | 11:04 AM
HeadsU.P.'s Avatar
HeadsU.P.
What Elired is referring to in post 10 is an old trick, proven winner, I read on this forum before.
In theory, loosening the fitting would sometimes flush any crap around the threads. Then tighten 'er down again.
Works? 90% of the time.
Costs? Zero
To Power steering fluid leak
