'77 L82 Push Rod Issue
I have checked and verified TDC several times but when I get the push rod adjusted to zero up and down play that is where I have a problem. After a 1/4 " turn I screw down the set screw and it only goes in a couple of threads. I sustututed an original push rod that was maybe 1/16 or so longer but I still have a lot of threads showing from the set screws. From all indications it looks like I need longer push rods. I have read about the push rod checkers but I just get terribly confused . I did buy one but it is a 6.8- 7.8 before I started this insstall. It's a piece of crap threads are very loose so waste of time using it. I have photos and will try to download what I have.
Looks like your E-Street heads have the +.100 valve length, but I cannot be positive of this.....if it is, you will be into at least a 7.900 pushrod.....and the valve geometry checkers that are available that set on top will not work.
The only way to correctly check your pushrod length is with an adjustable pushrod......and light tension springs.....on a small block you only have to do one as they are an inline valve setup.
This is a flat tappet setup....you need to double check the specs on those springs and possibly the valves too.....flat tappet stuff not only doesn't need +.100 springs, the springs you have on it look way to aggressive, they appear to be hydraulic roller springs. The studs look too long too....
You need to take a step back and double check everything as I fear you have some mismatch going on.....
Jebby
The one thing I do notice is the lack of assembly lube, even though you will prime it before starting, assembly lube is recommended...
60
I took my new heads to my engine builder before I installed them and he replaced them with 100 PSI springs just as you have suggested. So I guess I will have to learn how to set up the adjustable push rod and go from there. It's always a journey to get these old vettes back on the road. I just don't want to screw up this engine.
Thanks Again!!
Thanks Again!!
Though this is a lot of busy work to check it...the procedure is super easy.....just need the adjustable checker.....
Jebby
Something seems amiss. Most aluminum heads require a longer pushrod to keep the geometry in specs without retainer interference.
Often on aluminum heads, the rocker stud machined pad is higher. That moves both ends of the rocker arm higher. You have to make up for the higher distance by DOUBLE / TRIPLE checking and ordering longer rods. Figure $120 for one piece style, moly set of 16 for guide plates.
Something doesn't look right down inside the rocker in one photo. Why is the rocker ball offset? If the rocker nuts refuse to tighten then they are most likely shot.
If you didn't set the valve tip roller with light tension springs, the pushrod length is wrong......
Generally....and this is generally...you will be into a pushrod that is 7.850 on aftermarket heads......
Jebby
But in light of the "something to consider", first study up a little (lots of info on Google; just that some of it is bad!) on "proper" valve-train geometry. There are few different perspectives on the subject, and you seem to be aware of the intent for a centralized rocker arm roller to valve stem tip relationship, but this isn't the only consideration for a "proper" set-up, as in nearly anything there will be compromises. As a suggestion, look into the rocker-arm sweep radius value, which also presents a travel function in the relationship of the roller to valve stem end. I would suggest starting with the understanding of these two subjects and then just where does your set-up present itself in relation to them.
After you've optimized this perspective, then observe the related hardware that you have and its' ability to provide the proper mechanical fitment and function; if not, then one must ask if it would be appropriate to compromise the preferred geometry, in order to use what might be the improper parts?
An adjustable pushrod might be handy, but first I would just start with what I had, if only as this would only seem as perhaps an appropriate starting point; though the hydraulic lifter is a problem here, as the collapsing lifter plunger needs to be removed from the effort. If you happen to have an old mechanical lifter laying about, perfect, if you might have a hydraulic example, then pop the clip, remove the plunger, spring, valving, etc., and then shim the void until when you replace the plunger you've achieved the effect of a solid lifter, at the correct installed height (the clip will pop back in holding the plunger without excessive movement permitted); but do check that the two lifter heights agree (face of lifter to pushrod cup). Now apply your researched analysis process, and if then questioning the pushrod length you currently have, then maybe go ahead and purchase the adjustable checking pushrod.
B.T.W.: If following this process, and then if you selected some handy little washers/precision spacers (well maybe not so precision?) in the lifter body of your test lifter, then you could just start adding a subtracting washers, changing the lifter height (leave the clip out) as this would in effect be the same as having the adjustable pushrod (though not quite as easy to change distance of), and just measure the sum of the (precision) spacers/washers, and add or subtract from the existing pushrod length (saves buying something you might not ever use again?) And remember, that once deviating from the O.E.M.'s measurement the aftermarket generally addresses pushrod lengths in .050" distance changes (not mention what you'll receive vs. what was ordered), so this isn't truly so "precision" a measurement task.
Scott.
In your first post you mentioned you bought a pushrod length checker, but its maximum is 7.8 inches. You will need the next size longer. Something like 7.0 - 8.5
Looks like O' Reiley's web site has one, as does Amazon. They are only about $24. When you install it, put the adjustment nuts towards the lifter.
After doing your valve stem ink test. Back off the rocker nut and remove the checker w/o disturbing the length. You really need a measurement caliper for accuracy and not use a common tape measure.
Try to find prefabbed one-piece rods at Summit. They have common sizes for aluminum heads. (Custom lengths are expensive)
In the photos it appears you have the three-piece ball-end rods. Those ball-ends are a press fit. Will work fine for stock but any spirited driving will test those cheaper rods. The ball-ends will come out and destroy either the rocker arm and / or lifter. Not pretty.
Your rocker arm appears to be dangerously close to the valve retainer. Offhand I don't remember the minimum clearance, maybe 0.060 ???? but you could shove a feeler gauge between the two for reference. Longer pushrods will increase that distance, safely.
When building an engine....I spend a lot of time on the valvetrain getting the guide plate shift correct and the pushrod length spot on.......I am as **** about it as bearing clearance......when you get it right, your valve train will live a LONG time......
To the OP...you need to remove the head and do this right.....with light tension springs.
Jebby
Let's not have this turn into a forum of the level of so many other "KIDDIE" forums.
Scott.
