81-82 oil temp sensor interchangeable/replacement?
Old Sep 9, 2023 | 01:26 PM
78vette5.3's Avatar
78vette5.3
Default 81-82 oil temp sensor interchangeable/replacement?
I ordered an oil temp gauge with sender for my 78. I looked online for replacement senders and they are $100+ for the sensor!? I want to run two senders on a switch to monitor oil and trans temp. Is there a cheaper sensor with the same ohm range? I found the standard part number but it’s still $100+. I won’t pay that bc a whole new gauge and sensor is cheaper than that.
Old Sep 9, 2023 | 06:11 PM
MelWff's Avatar
MelWff
You checked with the gauge and sender supplier if they can sell just the matching sender? You can only use a sender that has the same ohm range as the one you already have.
Old Sep 9, 2023 | 08:26 PM
78vette5.3's Avatar
78vette5.3
yes the senders are dumb expensive. I don’t have specs on ohm readings to find a replacement. They range from $100-230 and im not paying that.
https://www.topflightautomotive.com/...hoCiK8QAvD_BwE
Old Sep 9, 2023 | 08:51 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Old Sep 9, 2023 | 08:55 PM
78vette5.3's Avatar
78vette5.3
What is crazy is I paid $86 for a new gauge and sender. Then the list the sender as $167!? Waaaaat
Old Sep 9, 2023 | 09:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
Crazy world
Old Sep 9, 2023 | 11:07 PM
Bikespace's Avatar
Bikespace
Buy the set! I'll give you $20- for the gauge you don't need.
Old Sep 10, 2023 | 09:25 AM
78vette5.3's Avatar
78vette5.3
haha I might take u up on that. The gauge and sensor kits done come with the mounting plate which I found out so I have to figure that out now.
To 81-82 oil temp sensor interchangeable/replacement?
