81 electrical help
Old Sep 16, 2023 | 03:56 PM
ole softai's Avatar
ole softai
Navigator
Default 81 electrical help
Having an issue with with my volt gauge. Old gauge went out and put a new in. Now when I adjust the lights on my dash with the light switch the volt gauge drops to zero. Installed a new light switch and same thing happens. If I turn dashboard lights off volt gauge reads normal. Still showing 13.5 at battery all the time. Also now my tack reads no lower than 1500. I have the shop manual and checked alternator and as many grounds I could find. It’s an 81. Car is mint and no issues before. Thx E J
Old Sep 16, 2023 | 04:13 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
I am trying to follow the events that happened.
Sounds like a dash bulb is making connection with volt gauge.
so,,, remove gauge cluster and inspect.
Old Sep 16, 2023 | 11:18 PM
ole softai's Avatar
ole softai
Navigator
Default Yes
Plan on looking into the plug behind the cluster tomorrow.
Old Sep 17, 2023 | 08:36 PM
ole softai's Avatar
ole softai
Navigator
Default Update
Checked plug behind gauge cluster. I didn’t see anything that might be a problem. Looked over wire diagram many times. When I disconnect the dk green wire that feeds power to gauge cluster lights from headlights switch ,volt gauge reads right. When sending power with the dimmer volt gauge goes to zero. I’m thinking the printed circuit is grounding. Can that be replaced. Thx
Old Sep 22, 2023 | 06:03 PM
ole softai's Avatar
ole softai
Navigator
Default Got it
Hope this may help someone in the future. After chasing my tail I changed the printed circuit board. No luck. Lots of trouble shooting and found the volt gauge itself was grounding to cluster housing. Just a little. Used liquid tape to make a gasket on back of volt gauge. That gauge is 1 year old. If it acts up again I’ll replace it again. Learned a lot about my c3
Old Oct 11, 2023 | 03:31 PM
RubbaBizkit's Avatar
RubbaBizkit
Hi ole softai -
Hey your issue sounds very similar to mine => https://www.corvetteforum.com/forums...auges-off.html
You think I might have the same ground-short as you? You have any schematics to share?
Thx
Old Oct 12, 2023 | 08:02 AM
RubbaBizkit
THAT makes allot of sense - I will have to schedule more time "inside" my sweet little '81 baby....
Thx!
To 81 electrical help
