inside lights not working....
Old Jan 21, 2003 | 09:06 PM
HcDave1's Avatar
HcDave1
Default inside lights not working....
i was wondering what happened.... it was working one min and then the next they dont work at all. The lights im taking about are the ones that come on when you opent he door. Anyone know what wire might have came lose or something along thoes lines???
thanks
Old Jan 21, 2003 | 09:13 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Default Re: inside lights not working.... (HcDave1)
check the fuse....mine don't fit all that tight and fall out sometimes...hehe
Old Jan 21, 2003 | 09:51 PM
HcDave1's Avatar
HcDave1
nope all good
Old Jan 21, 2003 | 10:00 PM
Tonwoo28's Avatar
Tonwoo28
Dave, on my 80 the horn and inside lights are on the same fuse. Is your horn out also?
Old Jan 21, 2003 | 10:58 PM
Gotta Fix my '76's Avatar
Gotta Fix my '76
On the passenger side behind the kick panel there is a white wire that connects to the push switch...check that and there is one on the other side, but I think it's green (it's to dark for me to check now)...but maybe those got wet or came loose, or the switch is stuck down..push & pull on the door switch thing to see if it'll come out...maybe a bad switch...I dunno, just a guess :smash: :smash:
Old Jan 21, 2003 | 11:20 PM
cchristo's Avatar
cchristo
This is usually a fairly easy fix. Check the basics first, the fuse and bulbs. Check for corrosion at the fuse block and the bulb socket. The chances of all the bulbs going out at once are slim but possible. Next thing I'd do would be to check the door switch on the drivers side. Try mashing it in and out a few times as far as it will go. That might knock off some corrosion. Next step would be to remove the kick panel and locate the wires going to the switch. It's been awhile but I think one off them is white. That area there is prone to rust or corrosion. The switches are pretty cheaply made and have a tendency to go out. Anyway, check the switch for visible damage. There should be two wires connected to it. If you look at it for a minute, it will be obvious how it's supposed to work. Each of the wires connects to a contact on the switch. Use your circuit tester to make sure you have voltage at one of the wires. With the door open, you should have voltage at both terminals. With the door closed, you should have voltage at only one of them. I've had to replace all of these switches. The same type switch is used on the alarm switch for your hood. You can get a good look at it there.
Old Jan 22, 2003 | 12:13 AM
Stoge's Avatar
Stoge
Check your horn and power antenna. If neither of those work either, its a fuse.
Old Jan 22, 2003 | 12:23 AM
HcDave1's Avatar
HcDave1
well the horn actually works...
but the antena, power door locks , and inside lights do not work.... so if its a fuse can you please tell me what 1 it is.....
thanks
Old Jan 22, 2003 | 12:28 AM
Stoge's Avatar
Stoge
Now that you mention it, my power door locks don't work either. (along with antenna, horn, and interior lights.
I'll go by and take a pic of the fuse location tomorrow and post it here.
Old Jan 22, 2003 | 01:41 AM
'79ProwlerOrange's Avatar
'79ProwlerOrange
Default Re: inside lights not working.... (Simon Alexander)
Sounds stupid, but check the radio fuse. mine blew once and took out my locks.
Old Jan 22, 2003 | 01:58 AM
77Dream's Avatar
77Dream
I had a problem where the hot wire came off my cigarette lighter housing and touched something metal. This caused all my lights not to work but didnt blow a fuse. I only found it because I was working on the AC control panel and bumped the wire and all my lights came on. It scared the crap out of me!!! :eek: And then when I went to put it back in its right place I accidentily touched the wrong thing and the fuse shattered, glass broke and everything.
The odds of this being your problem are slim, but it gives an idea of what the possibilites are. I hope its a simple fix. Good luck!!!!
[Modified by 77Dream, 10:58 PM 1/21/2003]
Old Jan 22, 2003 | 02:53 AM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
Only power things in my car that work are the radio and windows....took out most of the fuses though. Also that damn buzzer begged to be disconnected. So very irritating....lol
To inside lights not working....
